Question about Microwave Ovens
How do I replace the light bulb in the LG Solar Dom?
How to change light globe in microwave
EVER HEARD OF GOOGLE????
LG LMVM1935 manual
Google
That gets you to the manual.
Page 3 is the table of contents that lists oven light replacement on page 29.
Just maybe, if I teach you this you'll be able to do it yourself next time!
Sep 21, 2016 | LG LMVM1935 Convection/Microwave Oven
Replaced the bulbs underneath now they won`t turn off
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
The problem is on the controller assembly, which I regularly repair. Details are here.
I also have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2016 | LG LMV1813ST Microwave Oven
How to replace the light bulb in LG microwave oven.
Free LG Electronics Microwave Oven User Manuals ...
kitchen.manualsonline.com > ... > Kitchen Appliance LG Electronics
Products 1 - 50 of 141 - LG Electronics Microwave Oven 1SS6LMV1 8. LG - Life's Good Microwave Oven User Manual. Pages: 0 Saves: 0. See Prices
Sep 24, 2015 | LG Microwave Ovens
How does one replace the light bulb on the LG intellowave 924J
Most lamps are replaced from a door on the side of the oven
Nov 29, 2013 | LG LMV2083SW Microwave Oven
I have a LG Solar dom (Microwave oven). I have clean its inside 2 days ago as usual with some detergent and a wipe. Now the microwave is working . but as soon as I want to use the convenient oven it causes...
The oven has a heating resistance powering it. This heating resistance is fixed in the walls of the oven with some insulating bushes.
If, during the wash, some water has seeped in there because the bushes have aged and no longer sealing properly then the detergent in the water has acted like a short and the resulting flame has completely fried the bushing . This has now made the resistance to lose all the insulation and it's now shorting directly into the walls - such a big short is tripping even the greatest breaker in your house , the main one.
You should stop using the oven in this condition, the risks of electrocution are too high. Unplug the oven from the mains and call a repairman, he will have to completely dismantle the oven and replace the resistance and its insulating bushes - a long and expensive job.
May 31, 2011 | LG Microwave Ovens
Can't find light globe in MC924JLA LG Microwave
I think you're referring to the bulb which is not working. You have to remove the cover from the microwave to gain access to the bulb. Replacements can usually be found at appliance repair shops or stores and electrical or lighting supply stores.
Jun 21, 2010 | LG Microwave Ovens
The bulb has gone on my microwave. How do I change
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
Dec 22, 2009 | LG LRMM1430 Microwave Oven
I would like to know if it is possible to change a light bulb in the LG solardom Microwave without calling an electrician?
If your owner's manual doesn't cover lamp replacement, you will have to take the oven apart to do it.
If you don't have your manual, you should be able to download it from here.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's here.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Otherwise, please reply back with your model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | LG Microwave Ovens
Light bulb burns hole in the plastic cover
Same issue here. I just bought 4 covers from RepairClinic.com for $5.50 US each. I shipped them to my PO Box in Buffalo for an extra $6 bucks. Part number was 1206433
Hope this helps
John
Dec 23, 2007 | LG LMVM1945 Microwave Oven
Microwave Ovens Logo
586 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
