Question about Datalogic Computers & Internet
Configuring (changing) barcode reader suffix
I was told or read that it is fairly easy to change the suffix a Datalogic barcode reader uses after reading a barcode from 'enter' to 'tab' but I haven't been able to figure out how to do so, following Datalogic User Guides or using a Datalogic software utility.
    Problem Solver:
  • 6 Answers
Reset tbe scanner and again program the scanner for your required configuration.
Posted on Aug 16, 2008
Programming tab suffix
This manual may have the right barcode images to program your scanner.
http://www.posguys.com/download/QS6500BT_Manual.pdf
If not, a call to the manufacturer is how I solved the "how do I program the scanner" issue I had to solve.
Best of luck! Jon : )
May 30, 2013 | Datalogic QuickScan QS6000 Plus Bar Code...
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
I have a Datalogic Viper 9600/RF-3. The barcode reader boot in dos, not in windows, How I can install windows? I haven't communication cable. Can you help me, please? Thanks PD. Sorry my english.
Sorry to say its not possible to change the OS to windows. but i do have some vgiper.net's which are windows based. i could sell you. PM me for details.
Jul 12, 2011 | Datalogic DL9600 Viper RF (942804129)...
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
Problem with datalogic magellan 1000i barcode reader
hi
the cable is USB?
if you have usb cable, you read the manual paper "default".
if you have cable rs232 you must install on a PC emulator "softwedge". Open icons and set a comm. Prefer you answer. bye Roberto
May 16, 2008 | Datalogic Magellan 1000i Hands Free...
Configuring eclipse 5145
Turning off check digit sending and adding 4 suffixes: 2 cursors left and 2 deletes, solved the problem.
Apr 19, 2008 | Metrologic Instruments MS5145 Handheld
Will not read barcode correctly
La configuracion por defecto en el lector puede necesitar cambiarse para el tipo de codigo de barras que intentas leer. Descarga el manual para cambiar los parametros del tipo de codigo de barras que intentas leer. The default setting in the reader may need to change the type of barcode you are trying to read. Download the manual to change the parameters of the type of barcode you are trying to read.http://www.ute.com/files/manuals/103_MS210%20Users%20Manual.PDF
Dec 20, 2007 | Unitech MS210 Handheld
Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
Computers & Internet Logo
4,946 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
