Question about Pioneer Car Audio & Video
Does pioneer repair subs coils - Pioneer Car Audio & Video
    Master:
  • 752 Answers
Not likely worth the expense. They would send a new speaker.
Posted on May 21, 2011
How to wirea pioneer a pioneer tsw121 sub from4 ohms to 1ohm
That sub have dual 4 ohm voice coils, so it can be wired for either 8 or 2 ohms. It CANT in any way be wired for 1 ohm. Here is a diagram to wire it for 2 ohms.
Dec 09, 2013 | Pioneer Car Audio & Video
I purchased a pioneer cd player for my wife's
I'm pretty sure it is referring to the rca (low level) outputs of the deck. This means you will have to use an amplifier to run a sub.
Apr 24, 2012 | Pioneer Car Audio & Video
I have a pioneer 760watt model gm5100t amp and two audiobahn 12" subs and I would like to know how the wiring is configured from the amp to the subs as well as how the subs are wired since they are dual...
you bridge the inside + - and use the outside + -
then connect the outside + to the amp then connect the - to the + on the other sub then the - on the other sub to the amp just read this and do it slowly and you will get it then you only have to run the subs on a two channel amp
rate pls
Aug 14, 2010 | Pioneer GM-5300T Car Audio Amplifier
Help with hookup
I am assuming you are driving a sub-woofer. Run the amp bridged at 4 ohms. So a DVC(dual voice coil) 8 ohm sub with voice coils wired in parallel would give you a 4 ohm load. Just make sure the sub can handle at least 300 Watts Peak.
Dec 17, 2009 | Pioneer GM-3300T Car Amp
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
Prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
Mar 15, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Mar 14, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Sub not playing to full potencial
you haave either connected it incorrectly.make sure the ohm of the speaker matches that of the amp ..connect the positive coil to the positive coil at the back of the sub and the same for negative .then run your cables to the amp .you should only have one positive cable and one negative cable .this connection will create a 2 ohm connection make sure the amp can handle that load .prefarably using a 2 channel bridgable amp or 1 channel monoblock
Feb 20, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
How to repair a blown sub
i have a problem, i dont think my speaker is blown, but , it just looks like the wiring broke on the coil at the end that connects to the cone, i think thats how i can best describe it..its a 10" pioneer IMPP w/ integrated voice coil cooling system 500w max and also it looks like where the wires broke, the coil cam unglued from the cone.. hope someone can help me..is this something i can repair on my own or is it garbage?
Jan 05, 2008 | Polk Audio db400 Coaxial Car Speaker
Car Audio & Video Logo
15 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
