Question about Roper Dryers
Have to hold the button down to keep it running
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 26, 2011
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
When I try to start my mr. Heater I hold the pilot button down and the starter knob won't do anything? I can't get it to light the pilot, I've only had it a month.
Gas is turned on? Pilot button is in pilot position? Push and hold pilot button down, keep holding it down, push igniter many times, while keep holding down pilot button, keep holding until pilot lights. May take several minutes.
Feb 14, 2017 | Mr. Heater Heating & Cooling
How to put iPad 1 in dfu mode
Hi No 1 plug iPad to Mac or Windows. ,2 MAKE sure iTunes is running (3 turn off iPad .step1 press & hold down On/Off button for 3 seconds step 2 Swipe the slide to power off step 4 press&hold down On/Of for 3 seconds. Step 5 press & hold down the home button on the front while holding down the On/Off button step 6 keep holding down both buttons for 10 seconds ! If U c the apple logo U have held them down to long..start. Again...step 7 let go the On/Off button but keep holding the home button for 5 seconds.if U c plug into iTunes screen U have held it to long ..start again. Step 8 IF THE SCREEN STAYS BLACK"THATS IT" YOURE IPAD SHOULD B IN. DFU MODE.. i tunes should alert saying it's detected youre iPad and will allow it to b restored. If U c any logos U might b in recovery mode but not in DFU MODE IF RECOVERY MODE WORKS GREAT IF NOT TRY FOR DFU MODE ::::: good luck
Oct 26, 2016 | Cell Phones
Harley davidson 2006 dyna wide clide starts then just cuts out
Hold in the odometer button turn ignition you go to each letter hold it down. See a code write it down, then click to the next letter and do the same. At end of last one hold the button till it says clear. Shut bike off turn it back on and see if it runs like normal.
Aug 24, 2014 | 2006 Harley Davidson FXDLI Dyna Low Rider
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My Dell Latitude D620 laptop will not boot up unless I hold the power button down. The computer will run fine if I keep holding the power button down. It will also keep running if I hold down any key. As...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 04, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
My backett hell R7184B furnace is will not reignite when I hold the reset button down. I had run out of oil yesterday and believe I've bled all the air out of the lines. I held the reset button down for 30...
You may still have air in the line. You will need to hold down the button again with a hose on the bleeder screw and open it. Do this until no bubbles come out of hose. Just keep holding the reset down for up to a minute.
Feb 21, 2010 | Honeywell Heating & Cooling
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Dryers Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
