Question about Dryers
Makes Alot of noise that it is not supposed to be making while tumbling
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on May 26, 2011
I have a GE electric dryer and it makes a horrible screeching noise when tumbling. it tumbles and gets hot but when trying to manually turn the drum it gives me some resistance. whats the making this...
heatman101
Jul 25, 2011 | Dryers
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
When drum spins it makes alot of noise.
Check the main bearing and the pulley to make sure that they are both working properly if the bearing is bad it will make the drum bounce all over, if the pulley is bent it will make kind of a grinding noise along with things jumping everywhere
Feb 11, 2009 | Frigidaire FTF2140ES King Size Front-Load...
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Squeaking noise from Dryer when tumbling
IT IS USUALLY THE "BELT TENSION ADJUSTABLE PULLEY". MOST ARE CHEAPLY MADE ... TRY A BIT OF AXLE GREESE ON IT ... IT IS SEALED FROM THE INNER DRUM AND IS MOUNTED USUALLY ON THE BOTTOM FRAME RAILING.
Jun 25, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
