The model CS-21Z57ML flat screen samsung TV; The problem is no picture display but tuning system it work normal it include to search system.I replace video IC , vertical &horizontal transistor and tuning system estate it can,t solve the problem.how to solve this problem please help me.
SOURCE: Half part is display
replace ic
Posted on Sep 29, 2008
rjblittle
  • 54 Answers
SOURCE: my tv says no video signal and we have no picture
the cable connectors may be broken.you have to send it to get repaired.
Posted on Sep 18, 2009
  • 53 Answers
SOURCE: My tv Samsung HP-R4252, have Y-Main board
Do you have more specific information on your set, such as the full product model? Such as: HP-R4252X/XAA? What about the version?
This can help, because--as of right now--you are telling me that you put that Philips part into your Samsung TV. The LJ41-02759A is made for a range of Philips sets. They may work, don't get me wrong, but the part # for your Samsung set is: BN96-02033A
I don't have both these boards in front of me, of course, so I can't tell you if they cross or not.
Hope this helps.
Posted on Jan 22, 2010
  • 111 Answers
SOURCE: Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Posted on Feb 04, 2010
SOURCE: My Panasonic Viera television does not display
I have the same problem, Did you get it fixed?
Posted on Apr 26, 2010
My samsung tv model CS-5366z starts after five minutes ,what is the cause?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 22, 2017 | Samsung Televison & Video
My tv is a Samsung model UN46C8000XFXZA and like I said backlight are blinking and part of the screen is dark but I still have sound and picture
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. .
Oct 28, 2016 | Samsung UN46C8000XFXZA UN46C8000 46 3D LCD...
Samsung plano dnie jr flat screen tv : channels does not change with remote or by tv button, sometimes no picture is displayed the screen becomes blue
Main system control memory IC fault. Contact any service technician to replace it. This is not a work, that a user can do with ease.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 13, 2014 | Samsung Televison & Video
Can not switch on TV Samsung CS-21Z57ML, when I change the fuse, it blows
Short circuited component/s at its min power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 01, 2014 | Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
When I put on my Samsung Plano TV (Model is CS-20M16ML) the picture display after sometime becomes problematic. The blankness appears at the bottom of the screen and then gradually goes up and up thus...
Vertical output IC has the fault. Try this site named "Electro-help". You might get details from here. Type this name in google search box and click enter.
May 01, 2012 | Samsung WS32Z308P 32" TV
Please what is the factory reset for samsung tv.Modle Cs-21z58ml.
samsung tv MODEL CS-21Z58ML.no picture and low brightness problem has been re solved by replace the crt .if you found 4voltage for heater 190volt for scren still no picture you have to replace crt.but some times might be the micro chip on the circuit that its not pushing up the RGB's colors but most and common problem is CRT board.if you'll try to replace the transistors or ic.it will not change any thing.so guys letme know if you fixed it at costerntine@gmail.com thanks
Mar 07, 2011 | Samsung LN-T3253H 32 in. LCD Television
Adjust the screen/display size for CS-21K10MQ in normal view
This is a hardware fault and is usually related to the flyback transformer and some of the caps that control picture. It needs technical intervention
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Televison & Video
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Dec 30, 2007 | Televison & Video
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
