Question about Microwave Ovens
The blender blades of the magimix blender model 37BL51 turn and everything appears to work but no power in the blades to turn liquids at a speed
I have a blender thats been about 20+ years old... However, although I continue to use it well, lately it has been subject to leaking and other issues. I suspect that the rubber part (to hold the liquids...
Do you happen to know the make / model of your blender? If you do, you should be able to go to the manufacturer's website and order a replacement "o-ring".
Aug 17, 2011 | Microwave Ovens
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
I have been given a Magimix 3300 large food processor without a manual, and it hasn't been used for some years. The bowl seems to be jammed on ... is there a release button somewhere. I have had a...
All Magimix processors I have seen have not had release buttons to release the bowl/lid. It may be worthwhile you contacting Magimix themselves to see if they can help you.
Jul 02, 2011 | Microwave Ovens
I've got a broken Breville Ikon 550 blender. It smokes with in seconds of turning on, looks like the blade assy is broken as its little bit wobbly & gives resistance when turning. How & where can...
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 19, 2011 | Microwave Ovens
I need a gasket for my sunbeam blender/coffee mill model 2774 .
Hi and welcome to FixYa, I am Kelly:
Here are the parts that are available for your unit:
http://www.ereplacementparts.com/sunbeam-2774-blender-parts-c-116440_116442_116457.html?osCsid=rr7g7e3p7s5jfnk4rmdsk8cve2
I am assuming you need the gasket that is part of item 2 and comes with the blade assembly.
Note that it is back ordered and not available until 3/23/2011.
The part number is: 123250-000-000 Do a net search using the part number (images) and you will find other sources.
Thanks for choosing FixYa,
Kelly
Mar 12, 2011 | Microwave Ovens
Help!!!! I've forgotten how to assemble the grater component in my magimix 5100 food processor!
I believe the Magimix Instruction Manual is universal for al models. The manual can be found here:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download.pdf
The manual has illustrations of the assembly.
Mar 10, 2011 | Microwave Ovens
Braun immersion blender model 4172HB how to clean
I would be inclined to switch it on in warm washing up water. That will clean the blades.
Hope that helps.
Feb 28, 2011 | Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work...
sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Oct 06, 2010 | Microwave Ovens
I need to change the blade in my Braun blender, model 4 184. And I cannot loosen the old blade. I see no way to unscrew it. Please help
Just a suggestion: look underneath - there may be 2 prongs that you have to press together to push out, rather than having to unscrew it.
Sep 12, 2010 | Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
