Question about Canon Office Equipment & Supplies
I have MP540 3 years old. Attempting to print from computer - in the screen on the printer the moving arrows show for a few seconds and then reverts back to ready mode.
  • rowland_rivr May 21, 2011
    I'm running mac OS X 10.5.8
    Problem Solver:
  • 16 Answers
SIR First Off All Tell Me Which Windows r u Using Then I will tell you Solution
Posted on May 21, 2011
Error badint 0085ddc0
The 'badint' error on the T6100 indicates the printers firmware has for some reason 'crashed', this error should not be seen in normal operation of the printer.
One common cause of "BADINT" messages is the use of an external print server or host computer with incompatible parallel-port settings. If you have an external print server connected to the printer's parallel port there is a setting on the print parallel interface that may need changing, to change parallel interface setting. • Set the printer to Offline. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On) • Press the Mode key: display will show Offline Normal. • Press any Arrow key until display shows Offline Config. • Press the Forms/1 key. • Press any Arrow key until display shows Config Paralel. • Press the CPI/2 key. • Press any Arrow key until display shows Paralel Bi-Dir. • Press the LPI/3 key. • Press any Arrow key until display shows Bi-Dir Off. • Press the Enter key and the interface will be set. • Press the Clear key. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off) On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Nov 04, 2011 | Tally Line Matrix T6100 Printer
Says low black ink, will not print aligment page, was given to me by freind who was moving, don't have manuel or sofeware for computer. Have a Mac Book-Pro, not even a year old yet (the computer)
Try to re-seat the cartridges into the printer. Remove both cartrdiges > . pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds > firmly re-insert the cartridges. Let it print the alignment page.
If the display screen shows "low black ink" again, then try to replace the black cartridge. The printer requires all cartridges to have sufficient ink in them to continue printing. Try to replace your black ink with a new one, preferably a genuine cartridge.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Oct 12, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
When printing on the 4250, the margins are moved to the right of the paper cutting off the text. This is an XP computer and the PCL and PS drivers have been tested...
I would check to make sure that the paper trays are set properly and paper size is being detected properly. Print out the configuration page and see if that prints correctly. If it shows the same shift in image, check the paper sizes that the configuration sheet shows to make sure it is reading the trays properly. If the trays are reading properly and test print prints properly, then it is either your driver or the software you are printing from that has a problem.
To print the configuration sheet, press the down arrow button until the screen reads "information", press checkmark and then use the down arrow until "configuration page" is highlighted and then press the checkmark again. After a few seconds your page will print.
Apr 27, 2011 | Office Equipment & Supplies
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
Attempting to connect2026w monitor to a Toshiba laptop as a second monitor, It's now showing lots of gray screen and the wallpaper minus the icons and the arrow, partially awake, but not displaying ...
What graphix adapter and version of windows do you have? you need to locate the software to set up your video card and set it to "clone" images if you want a reproduction of the laptop screens pic on your new monitor.
Dec 25, 2009 | Office Equipment & Supplies
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can't print
It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
May 08, 2008 | Canon S 750 InkJet Printer
Left light blinks and i can't print anything
Open the cover of the printer, carriage will move out. Upside it you see a yellow arrow showing to on of 5 symbols. Left symbol means empty color cartridge, second symbol means empty black cartridge
Mar 11, 2008 | HP DeskJet 940c InkJet Printer
Error change unable 51
Unload the software. Restart the computer come off line. disable the anti virus Re install follow the prompts exactly. If still introuble take a look at www.fixyourownprinter.com
Aug 31, 2007 | Brother Multi-Function Center MFC-240C...
old marine
old marine
