Question about GE Spacemaker JVM1640SJ Microwave Oven
The plastic locking latch on my GE Spacemaker XL - Model #JVM1331WW 002 - broke. I have the replacement part and have taken off the plastic strip inside the door and the handle, but do not see how to access the latching mechanism to unscrew it. Please help!
MicrowaveSvc
  • 9098 Answers
SOURCE: the bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 09, 2009
SOURCE: where can I buy the handle of GE Spacemaker microwave?
amazon.com
Posted on Jan 04, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JVM1660 spacemaker XL microwave
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Apr 28, 2010
jsrock516
  • 5911 Answers
SOURCE: The door handle on my GE spacemaker xl 1400
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Nov 14, 2010
edwardafzal
  • 112 Answers
SOURCE: broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Posted on Jan 01, 2011
JVM1331WW 002 What is the cu. ft.?
The "13" in the model number means it's a 1.3 CF model.
GE Customer Service (here) can tell you if they have a "drop-in replacement" model.
Apr 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker Model JVM130G 002 (Date 1989) and the handle is broke. Does anyone know the part number of the handle replacement?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot remove handle to replace it.  The handle broke on top.
You must pry out the plastic strip that surrounds the window on the inside of the door to reach the top screw that holds on the handle. Be prepared to spend a pretty penny on the replacement handle as well.
Feb 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
