Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
Microsoft visual c++runtime librari - Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
  • 670 Answers
Are you referring to an error code or do you need to download it?
If you need to download, you can do so from the Microsoft Download Center.
however it's easier to do a Google search because MSVC++ has different versions (2005, 2008, etc.)
If you are referring to an error code you can go to the programs and features in the control panel uninstall the old version and download a new one.
Hope this helps!
Posted on May 21, 2011
3 Suggested Answers
SOURCE: in Adobe Encore /error loading transcode preset/
Follow this troubleshooting steps by using Microsoft KB http://support.microsoft.com/kb/307817
Posted on Aug 07, 2009
pcs365
  • 128 Answers
SOURCE: error R6002 floating point not loaded
Causes of Runtime Error R6002
Several causes exist behind this error. One of the most prominent ones is a broken link. This link apart from causing the run time error 06002 can also produce other errors like the computer not responding to any instruction at times. If a software has not been properly installed it can also produce such errors. Apart from that, use of internet without any anti-virus software can make your computer applications get infected with spyware and viruses. Such viruses can produce missing links inside your registry causing such errors.
Why are these errors caused? Many computer users are just not aware of the reasons resulting in these errors and what are the solutions to get rid of these errors. Remember, these errors can be solved very simply, and they are not going to cost you money. Usually many people exercise the option of getting professional technicians to resolve these problems. But this is not necessary. Through following the simple procedures suggested below you will be able to eliminate the error r6002.
If you take time and start noticing, you will find that the runtime errors are due to corrupted or damaged registry. You must know that the registry is the most importance place which is a storehouse of all the data, about both the software and hardware installed in the PC. When you uninstall software or remove a device there may be some traces of such actions left in the registry and manually it will be impossible to remove them. You should be having knowledge of computers to do this, since it is not advisable to access the registry without this knowledge and manually delete these files. A wrong move can result in damaging the PC irreversibly.
Therefore the only method to fix the runtime error r6002, along with many other errors, you should use the registry cleaner. With a registry cleaner you can repair the runtime error r6002 all by yourself, without seeking help of technician. This way you can save money and time, and you will also know the action to be taken next time when you encounter such errors.
Using the registry cleaner should be optimized with the antivirus cleaner, and if you program in such a manner that both the virus scanning and registry cleaner can take place simultaneously, for which purpose you should schedule these activities on the computer, and ensure that at that particular time the computer is switched on, without your botheration of checking them, they will do their job on their own, leaving you to attend to your work.
http://www.registryfix.com/?hop=reviewb
Posted on Jun 04, 2010
Runtime error Miss Popularity
You may need to remove Visual C++ then re-install it to the newest version. See link below:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinstall-Microsoft-Visual-C-Runtime-Libraries.html
Feb 27, 2015 | ValuSoft Miss Popularity: Your Style, Your...
Visual c++ runtime library runtime error!
then ur computer is running without latest Microsoft c++ redistributed version. Do a windows update.
Feb 09, 2013 | NaviCoder IDE for Java
:Error: the vc8 runtime Redistributable package was not installed successfully. Setup cannot continue
The Microsoft Visual C++ 2005 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2005 installed.
This package installs runtime components of C Runtime (CRT), Standard C++, ATL, MFC, OpenMP and MSDIA libraries. For libraries that support side-by-side deployment model (CRT, SCL, ATL, MFC, OpenMP) they are installed into the native assembly cache, also called WinSxS folder, on versions of Windows operating system that support side-by-side assemblies.
System Requirements
  • Supported Operating Systems:Windows 2000 Service Pack 3;Windows 98;Windows 98 Second Edition;Windows ME;Windows Server 2003;Windows XP Service Pack 2
  • Required Software:
  • oWindows Installer 3.0 Windows Installer 3.1 or later is recommended.
  • Disk Space Requirements: 6 MB (x86)
File Name: Size: vcredist_x86.exe 2.6MB Download
Jan 05, 2011 | Sony Computers & Internet
I was running Apex free 3gp video converter on a vista run computer and it pulled up the error sign Microsoft Visual C++ Runtime Library Runtime Error!
Microsoft Visual C++ Runtime Library Runtime, you need to download that and install it. This should clear the error. support.microsoft.com/kb/25940
Feb 19, 2010 | HP Pavillion DV6985SE Notebook
Microsoft Visual C++Runtime Library
hello there
please follow this link for a explanation and a fix for this ok
  1. "Microsoft Visual C++ Runtime Library Runtime Error" error message ... Describes the error messages that you receive after you install Office XP or an ... "Microsoft Visual C++ Runtime Library Runtime Error" error message after you ...support.microsoft.com/kb/307817
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
''Microsoft Visual C++ Runtime Library Error''.
You must go to start then control panel then add remove programs. After that remove Microsot Visual C++ Runtime. You must see it in the list. I hope that I help
May 18, 2009 | Dell Inspiron 1501 Notebook
Error messages. which cause my computer to crash.
what is your operating system?
what is internet explorer version?
if you answer these 2 questions I maybe able to help you resolve your problem
Nov 03, 2008 | Microsoft Windows XP Home Edition
Microsoft Visual C++ Runtime Error
Download
http://www.microsoft.com/downloads/details.aspx?FamilyID=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
Brief Description
hope this solves your problem it should
have fun
The Doctor
Nov 02, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
196 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
