Question about ASUS N73JF-XT1 Laptop Computer - Intel Core i5-460M 2.53GHz, 4GB DDR3, 500GB HDD, Blu-ray Player/DVD... PC Notebook
How do you remove the dvd from an ASUS N73JF. I removed the keyboard and backplate and the three screws,but the dvd won't slide out. What am I missing. Cheers for any help. Graeme
  • 36 Answers
DVD Drive is often holded by only one screw at the bottom side of the notebook. There might be a CD icon next to the screw. Look in the manual, there will be a guide for this
Posted on May 21, 2011
  • horkyze May 21, 2011
How to remove keyboard
First check under the battery, there will probably be 2 or three screws under it with small keyboard symbols next to them. If you can't find this, try unscrewing all the screws on the bottom of your computer that are under your keyboard.
After you unscrew each screw, store it somewhere so you don't lose it, and test to see if the keyboard can be removed. You should be able to lift up the part closest to the screen, and then slide it out towards the screen.
May 06, 2012 | ASUS K42F A1 Notebook
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
I can't remove the built in dvd rom, i tried to remove all the screws at the back panel but still it won't be remove
Did you remove the screws from both sides? You need to open both side panels and remove the screws. It may also be that the case uses a tool free slide system. Is there a latch you can pull, or push to set it free?
Jul 05, 2011 | Computers & Internet
Hello How do I remove the keyboard from an Asus A6J A6000 entertainment notebook? Thankyou
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus A6J Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus A6J Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
4. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right. Power on your laptop and verify that the Asus A6J Keyboard is working.
Dec 11, 2010 | ASUS A6J Notebook
Need to replace asus A3F keyboard
Push in the four tabs at the top of the keyboard with a small flat screwdriver and prise out the keyboard, there are no sercuring screws behind.
Feb 18, 2010 | ASUS Laptop Keyboard for Asus A3, A6, A9,...
How do i remove the cd/dvd drive for my acer3003lc so that a can replace it
You can use the Toshiba Satellite 5205 guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
for the acer 3000
1. At the back of the laptop remove the three screws on the support posts for the screen
2. Open the laptop fully and lift the plastic panel that has the power button.
3. Remove the 2 screws holding the keyboard in place
4. Carefully slide the keyboard towards the monitor and lift.
5. To the left of the keyboard ribbon cable is the screw that's been causing all this grief.
6. Remove, slide out optical drive, reassemble.
Jan 03, 2010 | Acer Aspire 3003LCi Notebook
Dvd rom does not light up and will not eject and definitely will not read discs.
First off, DON'T FORCE ANYTHING
1. On the back of the notebook remove three screws on the support posts for the screen
2. Open the notebook fully and lift the plastic panel that has the power button.
5. To the left of the keyboard ribbon cable is a screw that holds the drive in place.
Link to Acer pictures
Hope this helps...
Sep 25, 2008 | Acer Aspire 3000 Notebook
DVD/CD-RW
5. To the left of the keyboard ribbon cable is the screw hidden under the keypad.
Jul 11, 2008 | Acer Computers & Internet
Removing/replacing dvd rom drive
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Bill
Jun 24, 2008 | Computers & Internet
ASUS N73JF-XT1 Laptop Computer - Intel Core i5-460M 2.53GHz, 4GB DDR3, 500GB HDD, Blu-ray Player/DVD... PC Notebook Logo
430 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
