Question about Orion Televison & Video
How can I unlock the v-chip on my tv - Orion Televison & Video
ON CHANNEL LOOK CANT GET OFF OF IT
Hello
You must have its original remote control to unlock your RCA Tv. If you haven't one, just borrow it from any of your friends or relatives, who own the same model TV; just to unlock it. After unlock you can use universal remote.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
OK
Jun 19, 2011 | RCA TruFlat 27F520T 27" TV
Rca 27'' tv set can't acess cable chanels with remote or tv buttons tv was in fpa mode by mistake got out of fpa mode but when i push tv buttons lock on again
Hello
Just unlock its FPA by any one of below mentioned process. Reset the V-Chip settings later and try.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
May 08, 2011 | RCA TruFlat 27F520T 27" TV
My TV 13GP341 access code calls me, what should I do?
Hello
OK
Apr 26, 2011 | GE 13GP341 13" TV
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Rca truflat tv parental code is locked and channels are dark
Hello
Just unlock your RCA tv, by folloing the methods given below. One amoung them will surely unlock your V-Chip. After that you have to reset the V-Chip settings with an other code of your like.
OK.
Jan 07, 2011 | RCA TruFlat 27F520T 27" TV
Tv is locked asking for a code and the color has went out, what can i do?
Hello
Just unlock it by the following methods. One amoung the will surely unlock your TV. After that you have to reset the V-Chip and other settings according to its user manual.
Ok.
Jan 05, 2011 | RCA TruFlat 27F520T 27" TV
Can't remember the passcode
Hello
You can unlock your RCA tv without knowing the passcode. After unlocking it you have to reset with new pass code. To unlock it, do the follloing procedures. One amoung them will surely unlock your TV.
OK.
Jan 03, 2011 | RCA TruFlat 27F520T 27" TV
NO HAVE THE CODE TO UNLOCK IT. RCA MOD. 14N26
Hello
Your TV has been locked I thinks. There is a way to unlock RCA tv, and you must V-Chip code and other things later.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
OK.
Dec 07, 2010 | RCA E13344 13" TV
Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 29, 2010 | Mitsubishi WS-48315 48" Rear Projection...
I forgot the password for unlock the parental control
Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Jul 20, 2009 | RCA F27664 27" TV
Televison & Video Logo
20 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
