Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
KitchenAid door falls open - KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
SOURCE: KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Posted on Jul 07, 2008
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
Macmarkus
  • 2605 Answers
SOURCE: A spring or something has
Hello, Welcome to FixYa.
While I don`t have diagram or illustration I can give some insight because this is actually very common.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likey broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
Posted on Aug 18, 2010
  • 385 Answers
SOURCE: kitchenaid dishwasher kud102crwh1 issue: door opens
Broken spring.
Posted on May 23, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have a KitchenAid KUDS01FLSS2
Yes indeed that sounds exactly like the door springs being broken. The springs are fairly easy to replace, what needs to be done to replace the springs is remove the lowest service panel/kick plate and hook the springs on the tub support frame/leg and the other end goes on a notch in the door hinges. The part number for the spring is 8270182 they could be purchased at your local appliance parts store or online at;
repairclinic.com
apdepot.com
apwagner.com
midwestapplianceparts.com
Even though only one may be broke its advisable to replace both at the same time.
Good luck,i hope i have been able to help you fix your dishwasher,
Gene
Posted on Aug 13, 2011
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door falls open
The cables that are connected to the springs are broke, atleast one anyway. You'll need your model number off the machine to get them from a parts dealer. once you have them, pull the machine out a little ways and they install on the left and right side lower area.
May 28, 2012 | KitchenAid Dishwashers
How do you repair or replace the door tension spring on a KUDP01FLBT2 built-in Kitchenaid dishwasher? Thanks
If your door falls down or is noisy I have put together some instructions here on how to repair. You will need a kit part number 8194001, it is relatively inexpensive, let me know if you have questions.
Door falling down or creaking
May 01, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Good Luck, Tim K.
Jun 30, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Handle on oven door falling
Murray...after a DJ here in NY from the '60's!
First, why is the handle falling off? Is it loose or damaged? Most of these handles are only plastic with holes tapped in. If the holes are damaged and you can't fix them, you will have to replace. Most handles are through bolted in the door. You should be able to access those screws from the inside of the door. If not....
How do take a door apart: First locate any screws in the bottom of the door. Remove them. Open the door and remove screws from the sides and inside of door. Get help supporting the outside of the door and note that it will snap shut when you remove any weight from the door. Caution, most door glass is not well clipped in...it may come loose!!!! You may want to take pictures of the inside of the door once you open it. Once the door is apart, locate any fasteners holding the handle and attempt to tighten them. If not successful, you'll need that new handle. Get an extra set of hands to help with removal and reinstallation of that door skin. You'll need 'em!
Nov 29, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchaide Dishwash Door
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Jul 25, 2007 | KitchenAid KUDC25CH Dishwasher
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
163 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
