Element 32" flat screen was
  • Annie Anderson May 21, 2011
    Where can I buy the resistor part and can i see a picture of what it looks like?
    Thanks, Ann
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on May 21, 2011
  • 1,238 Answers
Good day!
Please open the cover of your TV and find where is the burn parts.Usually the parts or component that was burned is resistor please locate first on the power supply board.
After that replaced it with the same type,ratings and value.
Thank you
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Strong gas smell when oven is on
Bad heating element. Needs to be replaced. Depending on what you plan on replacing it with...call appliance repair shop with you model info and ask for quote to replace heating element.
Feb 10, 2013 | Kitchen Ranges
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
Screen is black and it smells like something is burning, but we cannot see any visable burnt wires or anything...we have removed the back of the tv, and looked at the circuit board...where exactly sho
Unless you know what you are doing you are playing with fire, Unplug the set and have someone qualified take a look at it. Smoke and a burning smell and you still have it powered up?
Apr 11, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a Element 32"
Unfortunately, components need their black smoke.
Once the black smoke escapes, the component is useless.
(ok, that's a tech joke)
It should at least be easy to identify what components blew when you open it up.
Mar 09, 2011 | Element Electronics FLX3210 32 in. LCD TV
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
