Question about Akai PT5250A Television
AKAI PT5250A I HAVE A AKAI PT5250A TELEVISION, THE HORIZONTAL OUTPUT GETS HOT, AND BLOWS. THERE IS LOW VOLUME, HIGH PITCH SCREEL WHILE IT'S PLAYING, THEN IT POP'S AND GO DEAD, H.O.T. SHORTED.
  • Akai Master
  • 8,617 Answers
You need a flyback.
Posted on Aug 15, 2008
  • Akai Master
  • 5,138 Answers
Slinteriors is CORRECT BAD FLYBACK TRANSFOMER!
Posted on May 16, 2009
No power for AKAI PT5250A
This is a main power regulator board fault. Check it. If you are not handy with high-voltage circuit board repair, ever attempt to continue, because, some capacitors at the power supply regulator board are dangerous to touch, even after you have unplugged the TV from AC mains supply line. They will have storage charge, that you could suffer by severe electric shock.
May 28, 2013 | Akai PT5250A Television
Monitor no raster power has been ok
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no High Voltage, you either have a low voltage power supply problem, bad start up circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have High Voltage as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
Use an ohmmeter to test the HOT for shorts. If it is bad, look for open fusable resistors or other fuses you did not catch.
Assuming it is good, measure the voltage on the collector-emitter of the HOT (this is safe if there is no deflection). You should see the B+ - probably between 100 and 150 V.
If there is no voltage, you have a low voltage power supply problem and/or you have not found all the bad/open parts.
If there is voltage and no deflection (no high pitched whine and no HIGH VOLTAGE), you probably have a start up problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for start up problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
If you hear the high pitched whine of the deflection and/or feel some static on the scree, confirm that the horizontal deflection and high voltage are working by adjusting the SCREEN control (probably on the flyback). If you can get a raster then your problem is probably in the video or chroma circuits, not the deflection or high voltage.
hope this helps......
Aug 06, 2010 | SAMTRON 77V 17" CRT Monitor
My tv has gone black how can i fix it or get a repair
Assuming there is no deflection and no HV, you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
(If you have HV as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
If there is voltage and no deflection (no high pitched whine and no HV), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
Jun 02, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My hm67 50 inch sond but not pic heard loud pop and lost pic
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself). See the section: Bypassing the Startup Circuit for details.
May 31, 2010 | Televison & Video
How do you fix a ps42p7 plasma tv that has sound and no picture. i have checked the cables and changed tv's and it is not any other source for the problem.
Assuming there is no deflection and no High Voltage , you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
If there is voltage and no deflection (no high pitched whine and no High Voltage), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osillator. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Hope this help
May 30, 2010 | Televison & Video
No Picture or sound
Good luck...
May 29, 2010 | Sony KV-32HS20 32" TV
Jvc flat screen
Hello, The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
If there is voltage and no deflection (no high pitched whine and no HV), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available.Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself). This require a skilled personnel to handle this
May 20, 2010 | JVC LT42E478 42 in. HDTV
HORIZONTAL OUTPUT OVERHEATING, HIGH PITCH SCREEL. BLOWING THE H.O.T.
whats the model number of your set and I will assist you with the problem, please respond to this same post with your model number.
Aug 13, 2008 | Televison & Video
High pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 04, 2007 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Akai PT5250A Television Logo
133 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
