Question about Ryobi Factoryreconditioned 12v Cordless Drilldriver
Hi i have a Ryobi cordless drill 12v CHP 412K ,I want to replace th chuck but i can not open the old chuck to replace. could u please help me or send me the a schematic structure of chuck. thanks Matt
5 Suggested Answers
  • 15 Answers
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
something is wrong. take it back if possible.
Posted on Oct 10, 2009
fisherman816
  • 66 Answers
SOURCE: my ryobi 14.4v cordless drill won't turn on. The
The problem is most likely the switch.http://www.ereplacementparts.com/ryobi-cordless-drill-parts-c-7931_8051.html
Posted on Nov 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: chuck removal on a ryobi
go to my site and under the tips section there is a detailed description on how to remove this chuck
Posted on Dec 12, 2009
SOURCE: My chuck key on my
ryobi drill with key less chuck will not open with a drill bit stuck in it
Posted on Mar 29, 2011
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Want to Replace chuck Keyless chuck always loosens and bits fall out.
Inside the chuck barrel there is a screw which unscrews counter clockwise, then
the chuck itself should unscrew counter clockwise as well.
May 09, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
Hello my drill bit holder is stuck open and the fingers that hold the drill bit won't come out of the housing no matter how hard I turn it.
If you go to this URL you will see a screw that is #1 in the exploded view.
http://www.ereplacementparts.com/ryobi-p206-18v-2speed-drilldriver-parts-c-7931_8051_8064.html
If the chuck on your drill is open you might be able to access this screw. It appears that this screw holds the chuck onto the drill and removing it might allow you to remove and then replace the chuck. I am not 100% sure of this, but it looks like a good place to start.
Sep 15, 2010 | Ryobi 18volt 12" Cordless Drill Model P206
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
Jun 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
Ryobi Factoryreconditioned 12v Cordless Drilldriver Logo
71 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
