Question about Siemens Washing Machines
We have a Siemans washing machine ( 8kg/651/XXXL/A+A S10-32 which has stopped with water in showing F18. What is the problem and can we fix it?
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
F18 is a drainage fault.
The appliance has a set time to drain if it doesn't drain within that time F18 appears in display
Diver 1
Posted on Feb 08, 2008
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
SOURCE: wf860
with my wt965a hotpoint ultima lcd fault code f 18 it was a reverse polarity on the main electric board of the house which means live & neutral are the wrong way round good luk dekka2
Posted on May 20, 2008
  • 56 Answers
SOURCE: washing machine won't let water out
pump blocked need to unplug machine and remove back and find pump this pump will need to removed and cleaned or replaced . if you do this your self you will blank or towels on the floor because there could be lts of water . Better to phone your local engineer . cheaper than manufacture.
Posted on Feb 11, 2010
SOURCE: my bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Posted on Dec 01, 2010
How do I remove child lock from a siemans washer
The display will have a icon for a lock. It may be for one or two buttons to be held for 5-8 seconds to unlock. It's the same thing as locking it.
Feb 29, 2016 | Siemens IQ-300 WM14Q390GB White 598 mm...
Siemens child lock
Unplug from mains for a few minutes and try again
Sep 17, 2013 | Washing Machines
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
Where i can find the spare parts for Homemaker hmwm6000 6.0 xxxl washing machine
Ask your local Kmart store for Homemaker's phone number.
May 29, 2012 | Washing Machines
What do I do when My machine shows F18 as an indicator of a problem
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
thank u
rate me
Aug 23, 2009 | Bosch Washing Machines
F18 Error
the error is caused by a blockage in the pump you need to drain the washer using the black tube near the pump drain or by unscrewing the pump cover next to it on excel 8kg washer these are at bottom right of machine. when all water out remove pump cover that you loosened to get water out then check for blockages inside. the pump has a device inside that should move round freely remove all debris replace and try to drain using drain cycle this will finish and hey presto back to normal!!
Oct 05, 2008 | Siemens Washing Machines
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
110 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
