Question about Garmin GPS
We have a Garmin 541 S with 2G vision card. 1/2 the time, a message appears that says Auto guidance unable to calculate route when we try " GUIDE TO". Is there something we may not be doing correctly?
SOURCE: No voice guidance
did u hook up your vss wire? vss is the vehicle speed sensor that might be the problem.
Posted on Aug 01, 2007
hydetech
  • 113 Answers
SOURCE: garmin nuvi 200 route calculation problem
Sounds like a major software failure. . .
Hold a finger on the upper right corner of the screen while powering up the unit. This should do a master reset.
The go here to download an update.
Posted on Oct 26, 2007
  • 504 Answers
SOURCE: garmin 660
Have you updated the software since you purchased the unit? If not, go to Garmin's site, download WebUpdater and check to see if there is an update to the unit's software. If so, download this and see if it helps. If not, try downloading the same version of the software again. This might help also.
Posted on Jan 28, 2008
  • 4 Answers
SOURCE: Route calculation Error on Garmin GPSmap 60CSx
Try re-setting your gps by simultaneously pressing the Enter and Page buttons while turning it on if that doesn't work check your firmware i found the latest one v 3.90 would shut off my gps when recalculating v 3.70 is stable Garmin know that the new firmware can cause problems
Posted on Jul 04, 2009
issikiki
  • 563 Answers
SOURCE: Garmin C550Calculates route and then powers off
Hello.
You can go to mygarmin.com or garmin.com . You have to register. It is for FREE. Then,you can update your GPS. You can also download maps by just following the screen instructions.
You can also find all the software/drivers you need there.
Hope it helps.
Posted on Apr 22, 2010
Cannot Calculate the route - Garmin Nuvi 3760
My probleme:
When you want to select (established) a route (Finding Location or Planing a Trip) the device machine can not calculate route and displays the following message: "Route waypoint memory is full". The device is Garmin 3760T.
I found the solution:
1. Start the device.
2. Touch "Wiew Map or Map"
3. Touch on bottom right of screen (Speed)
4. Hold your finger on top center of screen for 5-10 seconds (the speed semicircle between Trip A and Trip B). The unit would go into "Diagnostic Page".
5. Select "Clear all user data" and confirm.
Warning: will erase all user-selected data (Home, Recently Found, Favorites, Trip Planner, ....).
Mar 04, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
I tried to update my garman and now all I can get is the Message "Nodetailde maps foundthat support routing. The nuve cannot be used without them". how can I reset my navigator.
Call Garmin support
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Australia Hours of Operation Australia: Monday - Friday: 8:30am - 5pm EDST
New Zealand: Monday - Friday: 10:30am - 7pm EDST
Phone Australia Customer Support: 1800 235 822
New Zealand Customer Support: 0800 427 652
Jul 25, 2011 | Garmin nuvi 200W GPS Receiver
Soft version appears to be 0.00 .- Screen "Aquiring Satelites".- I tried with garmin support and they sent me an rgn file with an updater.- After following directions the following message...
Check the version of GPS SW. (Main Menu / Setup / System / menu button) If is says 0.0 then go to Garmin web site and get the chipset software to reload in your unit.Try it again the same procedure.This chipset software works mostly on all Garmin units.But if in any case if its not supporting then its a internal memory problem.If there is any external memory card connected to your Garmin unit then remove that external memory card and retry. ----------------- By any chance, when you turned the gps on did you press the power button multiple times? (Once to power on and quickly press again to turn on the back light?)This helps.---------If still nothing is helping then it has to be sent to Garmin service center for memory resetting.--------Thanks.Helpmech.
Dec 11, 2010 | Garmin Etrex Legend Hcx Handheld Gps GPS...
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 760 gps Unable to calculate route No roads near starting point
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Aug 02, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi Unable to calculate route No roads near starting poin
Its a problem you need to address with Garmin on this model before warranty runs out
Please rate our help to keep the FREE service onlinew++++Thank you for using FIXYA
Sep 11, 2009 | Garmin nuvi 350 GPS Receiver
Mar 09, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin Quest is out of whack
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Apr 04, 2008 | Garmin Quest GPS Receiver
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
67 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
