Question about Devilbliss DeVILBISS Devap DVH2600 Gas-Powered Pressure Washer
Got spark and gas can't get it running what is the conpression supposed to be
I have a honda power washer EXHA2424, I replace new spark plug, new gas., cleans the cabureetor, and it still won't start please advice me what to do
Posted on Jun 03, 2012
Gas in oil
Not suppose to be, but happens, remove the spark plug, and run the starter about 30 second, to clean the cylinder. Clean the spark plug and try to start it. When it's start it will smoke, but do not worry it will be OK, after a sort time. Good Luck
Mar 27, 2013 | Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
My 2005 yamaha ttr 125 won't start, I change the spark plug and the conpression seem ok. What else could be?
Hi, N_glutek and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
TTR 125 won start need help
Yamaha TTR 125 Won Start eHow
YAMAHA TT R125 Owner Service Manual
OEM parts for Yamaha
YAMAHA TT R110E Owner Manual
Apr 04, 2012 | 2003 Yamaha TT-R 125
Turns over will not start. have alread changed the spark plugs dis. cap and rotor. Could it be th coil? or a fuel system problem?
First check for spark at any of the sparkplugs.If you have spark then it is more then likely the fuel pump.You can'nt check the fuel pressure unless it is running.The fuel pressure is suppose to be 38-44 with the engine running.
Jan 20, 2012 | 1994 Geo Prizm
I have rebuilt the carb it is get fire and it still will not run (941av stiyl chainsaw) and it has 90% conpression
Use some starting fluid in the air filter or old school lighter fluid right down in the spark plug hole. Screw the plug in and try and start it up. If you get it to run this way it may pick up the fuel from the tank and run on it's on.
Aug 09, 2011 | Garden
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
2001 hyundai santa fe air conditioner the air conpresser works ad the blower works but can't get cold air.
might be the cooling gas freon
or could be simply the clutch that engaged disengage the compressor has a problem with its solenoid
Jun 14, 2011 | 2002 Hyundai Santa Fe
Stopping no power poor gas miles
CHECK SPARK PLUGS, AND WIRES, CHECK COMPRESSION AND CHECK FUEL INJECTORS IF CONPRESSION 9 OR 10 TO 1 CMP IS GOOD THEN REVERT TO SPARK PLUGS, ARE THE WORN, IF SO, REPLACE WITH FRESH NEW ONE.
Feb 21, 2011 | 2003 Chevrolet Suburban 1500
Power in the car but the car will not start , the battery is good, the starter is also good.
You need gas conpression and a spark to run with out all three your battery could be off a tank and still wouldnt start.
Apr 14, 2010 | 2004 Mazda 6
Devilbliss DeVILBISS Devap DVH2600 Gas-Powered Pressure Washer Logo
422 people viewed this question
Top Devilbliss Garden Experts
Dennis Key
Dennis Key
john h
Are you a Devilbliss Garden Expert? Answer questions, earn points and help others
