Boot problem Hi.. m havin a new dxktop pc..with asus p5n-mx.. duel core 2ghz.nd 1.25gb ram with inbuielt gforce chipset.... so my problem is..after swetching on my pc the screen remains black...nothin is goin on.. and after few mins its getin off..... but i went to asus my board is ok.. ram is also fine.. nd i hav put my cpu into my friends board..tht also fine.. means all parts r fine..but after getin together its not runing..... i have used it for 1 month.. suddenly this problem came on... plz tel me what to do.............
  • samrat123 Aug 15, 2008
    they hav checked my board ..its runing fine.. i checked my cpu to other board runing fine ram is also fine..so what oher parts u r talking about..
  • 1,800 Answers
I guess u didnt try another parts in ur board
i guess this problem is about ur board hurry up if u still under warrantly!!
thanx rate me ^^
Posted on Aug 15, 2008
Does ASUS P5GC-MX/1333 Motherboard supports DDR2 800mhz ram.?i'am havin 1gb ddr2 667mhz ram and i want to add 2gb 800mhz ram to it
Hello Tarun - No it doesn't. It would run OK but you would not gain any performance as the ram will only run at the same 667 MHz.
The limitation of RAM speed is dictated by the specs of the Intel 945 Chipset the motherboard is based on. But certainly add more ram, especially if your running Windows Vista or Windows 7 which both need at least two GB of RAM to perform well.
Happy upgrading and thanks for using Fix Ya.
Mikeywaf
Mar 21, 2011 | ASUS P5GC-MX/1333 Motherboard
I don't found my mother board driver so please give me motherboard driver of asus p5n-mx
Hi sandypodar,
You can find the drivers for your motherboard HERE. Once your on the page, Click Download then choose your Operating System.
Hope this helps.
Feb 23, 2011 | ASUS Computers & Internet
Giveme the download link of asus p5n-mx vga drivers. please it is very urgent sir please
http://www.asus.com/Product.aspx?P_ID=bLVB6rzf6bPajeg5
it's part of the chipset drivers
Sep 16, 2010 | ASUS Motherboard P5n-mx
Hi ... asus p5n-mx i format ma computer and i hve lost main motherboard cd so can u send that the all driver or how to download
Ok, you need to know what operating system you are tunning, I assume some flavour of windows. Go to this page:
http://support.asus.com/download/download.aspx?model=&SLanguage=en-us
1. In line "Select Product": - motherboard
2. in line "Select series": - socket 775
3. In line "Select model": - P5N-MX
4. Click on "Search"
5. In new open screen selelct your operating system
6. Select and download following files:
a. chipset driver
b. sound driver
c. utilities
7. Unfold these files to created folder (I create usually folder called "drivers" in root directory, you can create it on desktop), then run them following instructions.
As I do not know, you did not mention, what is your video driver, you need then find if you have build in video driver or you are using third party video driver. you need then to go to your video card manufacturer site and download respective driver from manufacturer site.
Hope this will help you sufficiently to re-install all drivers :-)
Aug 07, 2010 | ASUS Motherboard P5n-mx
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
Sir can i change my processor to dual core using this asus p5v800-mx?
Dear sir,
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
Aug 04, 2009 | ASUS P5V800-MX Motherboard
I want Asus P5N-MX Driver
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N-MX
There u go!, select your OS and download all the drivers you need
Good luck
Nic
Mar 13, 2009 | ASUS Motherboard P5n-mx
Insight/Decision help on new motherboard purchase.
talk about what you want with a computer repair shop
logically if the mobo is out of date , then you should be looking at the latest mobo and duel or quad core cpu
next all the os ,files and folders are on the hard drive and that can be installed in any new pc and will start and run
you have to consider this , the amount of ram has a bearing on the speed or the pc as it is used by the pc as a storage space as it moves data around as it performs the various operations
new mobo have 2 ram slots for 4gig ram sticks but you say that you only have 1gig of ram--compare 1 against 8 and see how much easier the pc will run
AS is said , talk with pc professionals ( not retailers ) and get the best advice before you flash the cash
Mar 05, 2017 | ASUS P5N32-SLI Deluxe Motherboard
Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
May 15, 2008 | ASUS P5NSLI (0610839134670) Motherboard
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Dec 19, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
David Payne
David Payne
