Question about Garden
My Ryobi PLT-3034YE Trimmer will not start ,have fitted new spark plug and replaced fuel to no avail
5 Suggested Answers
  • 297 Answers
SOURCE: I REPLACE THE FUEL LINES,NOW IT ACTS LIKE IT WANT TO START,BUT D'
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
Have a look at this drawing.
Posted on Apr 18, 2009
  • 8 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Posted on May 20, 2009
stmc97
  • 41 Answers
SOURCE: Can't get my Ryobi CS30 trimmer started, bought a
Is the fuel old or has it been drained and refilled?? Sometimes old fuel will do this. Also make sure the air filter is clean and free of oil/dirt as this will also hinder the starting.
The primer button also is something to check. Push it 7 times, full choke, pull for 5 times, turn to half choke, and the unit should start.
Let me know,
Chip
Posted on Apr 11, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Ryobi 700r 31cc 15" Trimmer,
Hi and wel;come to FixYa, I am Kelly.
The part you need is item 9 on most parts lists:
Your problem is caused by either drive shaft failure or.. clutch failure. Most of the time the drive shaft fails before the clutch.
The manual is here:
http://www.mymowerparts.com/pdf/Ryobi_String_Trimmers_Blowers_Tillers/700r.pdf
Shaft is PN 682064 or 753-04280
Sears parts direct has the shaft as item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/Model-700R/0909/1503820/10060718/00002?blt=06&prst=0&shdMod=700R
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/753-04280/0071/247/Model-700R/0909/1503820?keySuffixId=NA&productTypeId=x&searchModelNumber=700R&subCompDesc=Boom%20and%20trimmer&brandDesc=RYOBI&modelDesc=TRIMMER&pathTaken=partSearch&blt=11
Lower price here:
http://www.mowpart.com/p661995/Flex,-Shaft-(Rpls-682064)/product_info.html
Average price ($32.50)
Thanks for choosing FixYa,
Kelly
Posted on May 29, 2011
I have a Red Max HBZ2600 Z Power blower that starts runs a few minutes then slowly dies. Fixable?
Install a new spark plug
Clean or replace the air filter
Use only gas that is no more than 2 months old
& add fuel conditioner such as Sta-Bil or B&S,
unless you have to mix fuel for a 2 cycle motor
Once running & fully warm,adjust carb screws for
fuel mix at idle & fast rpm, then set the idle
Check for spark with a small engine tool avail for that
It looks like a spark plug with a clip on it & avail many places
May have to remove the carb,clean it & install a new kit,if
you still have problems
Jun 09, 2014 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I left my gas Ryobi Line Trimmer out in the rain on accident and now it won't start. I pulled the spark plug out and it looked fouled so I replaced it. It's still not starting with the new spark plug. I...
Try removing the fuel, remove the spark plug and give a few pulls to remove starter fluid from the cylinder, once completed attach your spark plug and check spark, reinstall plug, add fresf fuel to the tank and try staring with normal cold start procedure. Does it have good compression?
Sep 27, 2013 | Ryobi Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Problem with Ryobi Restarting
you need to replace the fuel filter in the tank ,must be fished out of tank with a coat hanger to the filler hole to be replaced
Sep 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 780 Trimmer No Spark - won't start
Hi
Check the spark at the plug,compression and carburation.Clean the air and the fuel filters.Check the muffler.
best regards savumihai71
Sep 17, 2008 | Garden
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
