Question about Dell Computers & Internet
Dimension 3000 switches on but does not boot up
  • Dell Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 21, 2011
Usb boot priority
Noah Lacina,
Unfortunately, the Dimension 3000 does not have the option to boot to a usb device in the system setup.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 19, 2013 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
I can't change boot order Dell Dimension 3000
Hi Thanks for your question
Please try to use "Esc" button to access BIOS.
Good Luck
May 05, 2010 | Dell Dimension 3000 PC Desktop
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from support.dell.com
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
Dimension 3000 won't boot until it gets warm
There's one way to find out - this is a list of power supplies for your unit on ebay, swap it out to see if the problem persists.
If you want to do it at the local level just find yourself a 400w ATX power supply that you can take back after testing (your machine may require a specific power supply and the ATX may not be mountable in your PC).
Post back with your findings.
Mar 01, 2009 | Dell Dimension 3000 PC Desktop
PC will not boot up
well when u upgraded did u format the hard drive u have to do that
Jan 20, 2008 | Dell Dimension 3000 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
