Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
My jbl 500 keeps blowing fuse at rear of speaker is there a quick fix for this problem ?
3 Suggested Answers
SOURCE: JBL PSW-D112 Speaker fuse blow immediately after replaced
The Problem in this unit is the Amplifier module S64AMI,which is surrended in a black heatsink, filled with epoxy, not serviceable, the bad news is that JBL discontinued this module and is really hard to find, sorry....
Posted on Nov 21, 2009
Grubhead
  • 5151 Answers
SOURCE: the fuse keeps blowing as soon as i power up jbl
You have an overload in the power supply or main amp of the subwoofer, often caused by short circuited transistor. Check this out by putting an ohm meter probe to each of it's legs. If it acts like you were touching the probes together you have found a guilty part.
Posted on Jan 12, 2010
Any way to Factory Reset a JBL Charge 2 ?
Yes, follow this sequence:
1. Turn the device on
2. Press the call (phone icon) and the volume up (+) button at the same time and keep them pressed. After a few seconds the speaker will shut down.
3. Release the buttons.
4. Turn the speaker back on. It will automatically enter into search mode... And there you are, memory wiped up.
Good luck.
Sep 19, 2015 | JBL Charge 2 Portable Bluetooth Speaker |-...
Harmon Kardon Receiver "Protect" Mode issue
If your receiver enters protect mode with no speakers connected, it is an indication that you will have to start troubleshooting inside.This will involve visual checking and checking with a multimeter to isolate the problem. A further issue is finding out why your JBL woofer keeps blowing fuses. It could be shorted.
Dec 12, 2013 | Audio Players & Recorders
Jbl subwoofer fuse
there is a short in the amp that would need to be fixed before the unit will power on
JBL EON 500 fuse location
I think it's between the power cord and the power switch.
Oct 15, 2012 | JBL EON 518S Subwoofer Speaker
Fuses keep blowing
This particular product has a lot of comments posted on it and I've answered a few of them now so I'm beginning to think you may want to look into weather or not the manufacturer has received any complaints or this is just a freak occurrence. Keep in mind not all commments are the same so this may just be nothing. Either way I can tell you this much, if fuses keep blowing quickly, over and over again-You have a direct short somewhere and will most likely be in need of professional assistance of some sort with the possiblilty of having to replace it. I'm sorry it's not an easier fix but it may not be too expensive.
-Dynami
Mar 22, 2009 | JBL PB12 Subwoofer
Psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Dec 28, 2008 | JBL PSW1200 Speaker
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
Jun 27, 2008 | JBL PSW-D112 Speaker
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
Keeps blowing fuse need parts?
You can email me : Franknguyen57@hotmail.com I will have part for you. Thanks
Aug 16, 2007 | JBL PSW D115 Speaker
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
77 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
