Question about ASUS Eee 4G Notebook
2 popup appears (1.EeePC Tray Utility saying: Intel igfxext.exe not running Disable Display Switch ho key 2.Asus acpi service saying: Intel igfxext.exe not running, Display switch hot key is void what should I do to fix this?please help
  • 217 Answers
SOURCE: Asus A6 laptop
Try clicking on Start->Run Then type in: services.msc and click ok. When the window opens, scroll down to the bottom where you should see Wireless Zero Configuration. Make sure this service is started. If not, start it, then go and try your wireless again. If it IS on... then you may want to try reinstalling your wireless card/adapter.
When you go to Network Connections, right click on the wireless connection and on the Advanced tab, make sure the box is checked to let Windows Configure Your Wireless Connection.
Posted on Jan 28, 2008
info2u
  • 596 Answers
SOURCE: wireless connection pending
I have seen this problem with many of my clients. Here is a way to correct your WLAN connection problem:
1: Choose "Network" in the Internet option, disconnect it and then delete the Connection in the "Manage".
2: Click "Create" to recreate the connection, choose "Local Area Network- Wireless", then Next.
3: Choose "Next".
4: Select Address Type, and then Next.
5: Browse Wireless Networks and then choose the one you want to use, you should see your wireless router/modem and the signal should show "Excellent" or "Very Strong". Choose the mode to be "infrastructure" and the Transfer rate to be "auto", and then Next.
6: Wireless Channel Settings, choose any channel.
7: If your AP is using the WEP or WPA encryption, you need to choose "Enable encryption" and then input the Key and Key index, (If you want your connection secured, you should use WPA and select a key index.) choose Next.
8: Fill in the Name of connection, then choose Next.
9: You can choose the "Connect automatically at system startup" or "Start this connection when finished" if you want, and then choose Finish.
This should correct your connection issues. Good Luck.
Posted on Feb 02, 2009
SOURCE: To upgrade my Asus Eeepc 4G
I've got the same little EEE as yours. I just did a bit upgrade my little one with a ram DDRII 2GB. That's the most it can go. I asked about the internal HDD, they said that EEE-PC has a built-in one. So, it ended up that I put an internal HDD into a box. That will solve it all. And...OH! I changed WINXP to Linux as well. That saved some space...I believe.
Posted on Feb 03, 2009
SOURCE: ASUS TRAY UTILITY
You need to go to the Asus download site, select your exact model of EeePC and then look for the ATK download.
The tray icon is part of the ACPI driver.
Cheers,
Andy.
Posted on Mar 11, 2009
  • 33 Answers
SOURCE: Error 17 when booting up Asus Eeepc 701sd
You should try to repair your windows. Which OS you are using...
Posted on Aug 30, 2009
Helpctr.exe unavailable asus eeepc using a
Follow the steps in the link:
"You cannot open Help and Support Center in Windows XP"
http://support.microsoft.com/kb/888018
Sep 04, 2013 | ASUS Eee Computers & Internet
I keep getting this message: "Asus Eee PC ACPI
Quoting from a forum last year discussing how to get rid of your message... "ACPI stands for Advance Configuration and Power Interface, which basically means it lets the OS communicate with the BIOS. This covers things from properly reading battery capacity to hardware features like enabling the Fn keys on your keyboard to work. So it's needed if you want everything to work." Click on the following link to see the discussion thread...
http://forum.eeeuser.com/viewtopic.php?id=86722
The problem can be registry errors, incorrect ACPI drivers or both. You can try the suggested solution of reloading the Asus drivers but you may still get the message due to registry errors. Registry cleaning can by done by Advanced SystemCare Free which is a free utility that can be downloaded from CNet...
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
If all this fails and you can back-up any personal data that you might have on the netbook, a simple solution is on startup to tap F9 to reload the system with its factory-installed image that is on a hidden partition on the netbook's hard disk. Click on the following link to read and follow the steps....
http://www.jabzweb.com/tips-and-tricks/2009/10/how-to-restore-your-asus-eeepc-netbook-to-factory-settings/
Mar 11, 2011 | ASUS Eee PC 1000HE Netbook
It this message keeps coming up! What do i do?
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Sep 11, 2010 | Computers & Internet
My Webcam is built in and my computer is not recognising it. i went into its software and it told me to try to turn on integrated webcam. i am using windows 7 starter and i need my webcam.
download and install: 1. ecam utility http://dlcdnet.asus.com/pub/ASUS/EeePC/Utility/ECam-V2_0_2_3.zip
2. Livcam Utility http://dlcdnet.asus.com/pub/ASUS/EeePC/Utility/LivCam-V1_0_9_1.zip
Aug 11, 2010 | ASUS Eee PC 1005PE (SeaShell) Netbook
NON RICORDO PIU LA PASSWOR DEL MIO ADMINASTRATOR Eeepc 4g xp
Try "F2"" whilst ---Booting----
Disable password enablement or/and restore to default settings.
May 13, 2010 | ASUS Eee 4G Notebook
Keyboard\service.exe not found error
This is a virus that infected your computer. There is no "keyboard\service.exe" file in Windows. Your antivirus likely removed it but it's still trying to load up on start up.
Go start->Run and type in "msconfig"
Then go to the startup tab on the window that appears and look for that particular exe file and disable it. You shouldn't get the message anymore.
Also clean your harddisk wint an antivirus program
Aug 03, 2009 | Computers & Internet
ASUS TRAY UTILITY
Cheers,
Andy.
Mar 11, 2009 | ASUS Eee 4G Notebook
Cant find webcam file
Did you check the bottom right hand corner for of your laptop for "EeePc Tray Utility"? If you haven't double click on it and then click on enable/disable camera to turn off and on your webcam! Hope this helps!
Dec 15, 2008 | ASUS Eee 4G Notebook
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: IntelĀ® Chipset Software Installation Utility for IntelĀ® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
ASUS Eee 4G Notebook Logo
558 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
