Question about Canon PIXMA MP470 All-in-One Printer
Have canon mp470 on mac want to print double sided
5 Suggested Answers
  • 41 Answers
SOURCE: Canon Pixma 4200 does not print double-sided with Mac
First, I'd strongly suggest you update your drivers.. there are newer drivers that came out in Nov 07, Dec 07, Jan 08 and even Feb 08. Here's the link to Mac OS drivers for your specific printer...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11641#DownloadDetailAct
Please download and install all of the applicable drivers/software, because I have found that features such as color management come from the Easy Photo software, not the driver stuff.
The second link here is the directions on how to set up the duplex printing in Mac OS systems. It's a step-by-step and seems pretty comprehensive.
Good Luck!
Let us know how it works out for you!
Maggie B
Posted on Feb 23, 2008
SOURCE: Canon mp470 will print but not scan. Does nothing
what OS? probably missing twain driver. Is it usb, parallel, cat 5?
Posted on Aug 04, 2009
seanpwright
  • 2030 Answers
SOURCE: Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Sep 11, 2009
  • 739 Answers
SOURCE: Canon Pixma MP470, paper feed not straight
Hi Dave
First thing to check is that the left hand paper guide (as you look at the printer from the front) is up tight against the edge of the paper stack in the feeder. I've seen many printers where (over the course of day to day use) the paper guide has progressively moved itself to the left so that the paper is not held at all. The pick-up for the paper is at the bottom right hand corner and if the guide is loose the paper can skew as it goes in - and then it only gets worse.
Another possibility (and this has just happened to me) is that the long piece of sponge that runs the length of the platen (you'll only see it if you open the top and shine a light in) has come adrift slightly. Mine actually came completely out after 2 or three skewed/crumpled sheets. I washed it, dried it out with kitchen towel and then carefully refitted it. Now the printer is running like a demon.
Let us know what your outcome is.
Posted on Dec 06, 2009
Canon MP470 prints colors light on Mountain Lion
So go back to former driver since this one does not work. A no brainer!!!!!
Aug 28, 2017 | Canon PIXMA MP470 All-in-One Printer
Trying to re-install MP470 driver onto my MAC but it won't install even though it says it installed successfully. It doesn't show up on Print cue and I can't find it on hardrive after 3 installs This...
go into the contro panel (if mac has this) and remove the printer and its software (and driver) completely. now reinstall from the disk or your download.
Mar 11, 2011 | Canon PIXMA MP470 All-in-One Printer
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
Feb 05, 2011 | Canon PIXMA iP90v Printer
My Canon MP470 is printing blank pages when I try to print from my Mac. It works fine from my PC. I find this ironic because I got the printer for free from Apple when I purchased my Mac.
During certain cases, you might have completed the physical integration perfectly. But still, you might not be able to accomplish the printing. This could be due to the absence of a driver installed in to your system. The problem could easily be averted, if you are installing the driver corresponding to the manufacturer. You might ensure that the version corresponds to the exact version of the printer series also.
Jan 19, 2011 | Canon PIXMA MP470 All-in-One Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon MP470: paper stuck
Unfortunately you need to disassembly the hole printer to solve the problem.In most case the object who block the paper is under the withe rollers and you can't see it from above.
Oct 12, 2009 | Canon PIXMA MP470 All-in-One Printer
Sep 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon mp470 not printing tried to upload on mac book pro ..it says it sees it but  nothing printing..when asked for a print driver to install printer it does not give me the option to choose canon mp...
Download the most recent driver for your printer from the Canon website and install it. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=15403#DownloadDetailAct
Choose the Drivers and Downloads tab, select your OS and the then download the correct version. That usually takes care of it.
Aug 29, 2009 | Canon PIXMA MP470 All-in-One Printer
Printing pictures
If your normal print looks OK, make sure that you are printing your pictures on the correct side of the photo paper. Most photo paper will only print properly on one side. If you print on the other side, the image looks very grainy and faded, and the ink will still be quite wet when it comes out of the printer.
Jun 12, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon PIXMA MP470 All-in-One Printer Logo
81 people viewed this question
old marine
old marine
