Question about Sub-Zero MW24 Microwave Oven
Wolf microwave MW24 installed in 06..light comes on, timer counts down, nothing else..wont heat, turntable wont turn
MicrowaveSvc
  • 9047 Answers
SOURCE: Maytag over the Range Microvave MMV5186AAS does not heat.
You have a bad secondary interlock (top door switch) or its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 01, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Intermittent Panasonic Microwave Operation
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: wolf - microwave oven not turnin ON
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jan 23, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: MCM1290A Microwave Oven: the timer counts down but it wont heat or the turn...
Probably a bad door switch. See this file.
Posted on May 06, 2010
No heat generated in microwave or convection oven mode
I just read that starting the microwave as usual and then slightly pressing in the handle (you can hear the heater(?) come on will make the heat come on. Tried it and it works. My repairman told me it needed a new magnetron ($700) but that was totally wrong. I will be trying another repairman to replace handle mechanism.
May 11, 2013 | Sub-Zero MW24 Microwave Oven
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Stopped turning and heating
The problem is one or two bad door switches, "more than likely" the less likely is the keypad control board.
Apr 12, 2012 | Kenmore Microwave Ovens
My Pro Series Frigidaire Microweave oven is not heating. The turntable is not turning but the light is working and the timer is counting down.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 10, 2011 | Frigidaire PLMB209DC Microwave Oven
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Everything seems to work fine until you hit the start button than nothing happens except the timer starts counting down
If everything appears to be working normally, as you say the timer counts down, the light comes on, turntable rotates etc. then the problem will be linked to the magnetron not operating & not heating the food. This could be just a thermal fuse device which may have gone faulty but if it is a magnetron fault then the cost of getting this replaced can be expensive & it might be more economical to buy a new microwave. I would advise taking it to a local repair centre, one which gives free estimates to get a quote on a price.
Jul 27, 2009 | GE Microwave Ovens
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
Microwave Ovens Logo
1,014 people viewed this question
Top Sub-Zero Microwave Ovens Experts
William Miller
William Miller
Are you a Sub-Zero Microwave Oven Expert? Answer questions, earn points and help others
