Question about Samsung CLP-510 Laser Printer
I have a CPL-510 , one of the top orange rollers has started to disintegrate and has a couple of chunks missing. can I get spares or a repair
  • Samsung Master
  • 4,338 Answers
Contact this company, I have had good results from them:
http://www.precisionroller.com/all-supplies-and-parts-for-samsung-clp510/products.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 21, 2011
My CPL 510 does not fuse all colors to the paper
Dear
from the Question I understood that the image formation and transfer to the paper is OK. Since the the toner used in for toner carts. are same properties except color of toner. If any of the toner carts. used other than recommended toner,this may happen.
If some of the area on paper or continuous, are not fixed (may be checked on wiping after printing) irrespective of color, Then there may be problem with fusser assy.
Before checking Pl. confirm the paper used and the paper setting on driver on PC to be matched.(fusing temp. is different for different paper).
Also check the printer service life. fusser assy. may be checked for toner stoked on the surface of the heater roller as well as on the pressure roller also check its surface for even pressure.
Thanks.
Feb 02, 2015 | Samsung Office Equipment & Supplies
Where do you find parts for cpl-510
Ebay sells a variety fparts for Samsung. If you want to buy new parts. PRECISION ROLLER SELLS NEW PARTSFOR SAMSUNG.(800)323-9523
Aug 13, 2012 | Samsung CLP-510 Laser Printer
A pan stuck to the glass top on the front right burner when the burner was on. When I removed the pan it took a couple of chunks of glass with it. Now there are two chuncks of glass missing from the...
Sorry to read about your problem, I hope this helps you out.
You are not going to like this, and you did not give the model number of your unit. But glass replacement tops, will range from $600.00 to $800.00 just for the glass top. and their is not a way to make repairs, because it is a special glass.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Microwave Ovens
I just started receiving some paper jam errors. When I opened the back cover I noticed there is a huge chunk taking out of an orange foam roller and orange foam bits are all over inside my brother printer....
Sounds like your fuser is toast. I would contact Brother and try to get it replaced on warranty if it still applies. If not, it's basically dead. Sorry.
Jan 14, 2010 | Brother MFC 7840W Printer
Paper jam top o printer
disassemble printer and clean rollers with a rubber rejuvinator solution
Nov 21, 2008 | Samsung CLP-510 Laser Printer
Dryer makes a very loud noise when turning - sounds like something is grinding. Happens on both directions of the spin. Could this be faulty or worn bearings? It is a condenser dryer, 4 yrs old
The drum support roller for your dryer (s) is worn out. In Rozzi's case is sounds like the rubber has come completely off and the drum is turning on the bare metal part of the wheel. In guest's case is sounds like one of the rollers has a chunk missing from the rubber that normally surrounds the metal wheel.
Unplug the dryer. Pull the top off the dryer. Typically a couple of screws in the back and then slide the whole top towards the front of the dryer. Lifting from the front edge open it up like a chest. Remove the drum and the belt. You should see two drum support rollers. Replace them both (and the belt while you are in there).
Sep 23, 2008 | Dryers
Documate 510 scanner ADF problem
Hello.
I am a Support Engineer with Xerox Scanners.
If the feed rollers are worn out beyond the point of cleaning, you will need to have the scanner serviced or replaced.
Please contact us to discuss your service or replacement options by calling 800-648-0410.
Regards,
Xerox Scanners Support
Dec 07, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Samsung CLP-510 Laser Printer Logo
57 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
