Question about Curtis CM13102 13" TV
I bought a Curtis 13"
I'm
Having the same problem
With the one I just bought
Posted on Sep 14, 2012
2 Suggested Answers
SOURCE: curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
Posted on Apr 26, 2008
My TV has a white vertical line about 8 in wide on the right side of the screen followed by a few blurry vertical line going toward the center of the screen the left side is fine
More burned capacitors.. You have a center and sometimes a right and left circuit board. If you have to visit the board more than once in just a few months you will have to call the LG tech. You need to replace one of the boards. I tried the self repair route and nearly ruined the TV. Take it from me ...call the tech.
Jul 06, 2015 | LG 60PV250 60 in. Plasma HDTV
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
My dlp hl-s4266w had developed a 10 " wide vertical darker area than the rest of the sceen
Usually this will be on top or either side and the problem is the optical light engine is damaged from heat----seen about a dozen.
Dec 04, 2012 | Samsung HL-S4266W 42" HDTV
Picture on my CM25101S has gotten larger, can't see tops of head and the bottom of the sceen
The problem you are describing is a vertical deflection problem often caused by one or two open capacitors near the vertical ic.
Mar 18, 2012 | Curtis CM25101S 25" TV
HI When I start my ALBA TV, there are horizontal lines across the screen with high noisy sound. I bought this TV just few months ago. thank you
The horizontal line in the screen is the problem cause by vertical output driver.The vertical output is located at the verical section.Maybe theres a loose connection in vertical section or leaked capacitor.It also the cause of deffective vertical ic.So its better to repair and trouble shoot by the authorized technician.If you have knowledge in Tv.Try to replace the leaked capacitor.
Jul 17, 2011 | Televison & Video
Picture tube failing?
NO thats not the picture ,that is more from the vertical circuit some capacitor defect or the ic it self
hope thet will help you
regards Alan
Jun 07, 2010 | iLO 2600 Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Brother MFC7820N
I assumed you are using a digital copier/printer, in digital machine there were 2 kinds of diagnosing a problem, and you are right with your observation Copying and Printing, and each have two separate troubleshooting.
If you say that in printing is fine, then the problem is with the scanning part which is in your Optical Unit, here's some pointers
1- Open the optical glass on the top, with screws
2- Observed the optical unit with 3 reflective glass, it could be dirty
3- the middle of the optical system is called the CCD which converts the image from the reflective mirrors, see if you can find dust and dirt.
4- Check the lamp for any sign of dirt this could cause also some problems.
these are the only areas you need to check, nothing else, and this would surely solve this problem
Jul 15, 2008 | Office Equipment & Supplies
Has anyone else had this problem?
I bought the same tv about a year ago. I noticed that the power adapter gets very hot when plugged into the electrical outlet so I unplug it after watching tv. Better to be safe than sorry.
Jun 26, 2008 | Curtis RT700 7 in. Portable Television
Curtis CM13102 13" TV Logo
65 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
