Question about HP Office Equipment & Supplies
I purchesed a HP Photosmart D7460 Printer.It took up to20 minutes to start intermitant printing. After the welcome to Photosmart Express Please insert memory card comes up and then ink usage symbals change back and forth.If I try to reboot the computer a sing comes on to say that the printer spooling will not alow the computer to shut down.I have Uninstalled,Re started,unpluged printer.USB then re installed but the printer did not re appear only all the other programes. What do I do wrong and as a Senior who has no training and am just a plodder Please help me. David Hadley
  • david. hadley Aug 16, 2008
    I don't understand the answer I recieved.I conot follow how i get from one section to another.I am useing XP and with my very limited knowledge I cannot getto the printer driver to start so I am not sure how I will go with any further progress with out my instructions being simplified please take care of this old fellow as i am trying to print our retirement village News Letter.
    I must be Dumb,I cannot work out what to do or wich Restart to use after right-Click Spooler because what ever I do I dont come up to be able to continue on with ..Click start Click printers because i cannot find printersto right clickon
  • 1,498 Answers
Hi David,
My name is Mike, I'll walk you through it. If at any point you would like clarification, just ask. OK?
  • Click Start
  • If there is a Printers selection, Click it.
  • If not, Click Control Panel, Then Click Printers.
  • Find the icon for the problem printer. Right Click it.
  • Click Delete. If it doesn't let you, stop here and tell me what it says.
  • Next we will uninstall the software
  • Click Start
  • Click All Programs
  • Find the HP Software, see if there is an Uninstall Option and Click it. If there is no Uninstall we will take another route.
Let me know when you are ready for more (the re-install)
Mike
Posted on Aug 16, 2008
  • 1 more comment
  • Justin Case
    Justin Case Aug 16, 2008
    David,
    The Printers option doesn't show on every Start Menu. Choose the Control Panel option in the Start menu. You will find the Printers Icon.
    From there we can Uninstall, then re-install the software.
    Mike
  • Justin Case
    Justin Case Aug 17, 2008
    David,
    I know where you are getting lost. My version of XP is the same as yours (and a little different from the normal). The assumptions made by some of the experts don't take these differences into account and can be frustrating. I also have an HP Photosmart printer. I've been through it too. I can help.
    I do remote support all the time, I'll get you through it step by step.
    When we're done, people will come to you for advice. Hope you see this to respond.
    Mike
  • Justin Case
    Justin Case Aug 18, 2008
    Hi David,
    Mike here. Lets start from here, Ignore previous comments. I'll repost the necessary procedures. Troubleshooting difficult problems is as much ruling out possibilities as it is searching for a cause. We're going to do both.
    To do this, I need some additional info, If you could confirm or clarify the the following:
    • When you installed the drivers, the printer USB cable was not connected until the installation software prompted you to connect it.
    • Your printer is wired directly to your computer using USB cable. (No hubs, not wireless)
    • What is the size of your hard drive? (Right click the drive icon in My Computer and select Properties. It will show a pie chart. I'm looking for Capacity)
    • Same place, What is the available space?
    • Are any errors displayed during startup? When Printing?
    • What software are you using to print?
    The answers to these questions will help in troubleshooting your problem.
    Now lets rule out half the possibilities:
    The first test I want you to run will determine if the problem is in the hardware or the software. This is done through the printer console by generating a self-test page and timing how long it takes to print.
    The time measurement does not have to be exact. The average time to
    print a self-test is 30 seconds.
    1. Load the printer with plain, white paper.
    2. Press
      Setup
      on the control panel.
    3. Press the down arrow until Print Report
      is selected, and then press
      OK
    4. Press the down arrow until Self-Test Report
      OK
    5. Begin timing when the paper feed rollers start pulling in the paper to
      start printing, not when the first noises come from the product. Stop
      timing when the printed page falls into the paper tray.
    If
    the test page prints in less than or close to 30 seconds, the product
    hardware is working correctly.
    Get back to me with the results or any questions. We proceed from there.
    Mike
  • 10,594 Answers
Hello old fellow,
I don't think you would understand all above / below Computer technical instructions properly. thus, I would advise you to call a computer literate person from neighborhood and ask him to install the printer. Thank you.
    Master:
  • 521 Answers
To make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
pls do rate the solution if helped. thanks.
  • 1,800 Answers
Okay okay sir with me every thing is gonna be okay the whole vilage will bebenift from ur printer just follow me!!
1/uninstall the printedr "its like starting from zero."
2/run a little antivirus scan
3/insatll the printer without connecting it to the computer
4/ when the instalaqtion is finished connect it
5/press ctrl+alt+del look in the processus chapter check if there a spools.exe service is runing if its not running do this
6/start/run/type msconfig/service/activete the spool service its there just seek for it(in case if not already activated)
7/apply /ok /rebbot
print a test page and see whhat happednd tell me okay??
rate me!!
  • 69 Answers
First, click Start.
Then click Run.
type services.msc
scroll down till you find Print Spooler.
Right-click Print Spooler and click Restart.
then...
Click start.
Click Printers
Right-click the printer you use and click 'properties'
click on the spool settings tab
and make sure the spooler is not set as RAW. (you will see the options on that page)
If you need any more information, please ask before rating!! thanks!
  • Samuel Ward Aug 17, 2008
    If there are no printers under the printer list, you need to install a printer.
    Master:
  • 848 Answers
  • In Start, Settings, Printers, click the printer driver with the right mouse button, Details, Spool Settings, change Spool Data Format settings from RAW to EMF or vice versa.
  • In the Spool Settings, select Print directly to printer.
  • In Port Settings, try unselecting everything that is check-marked.
  • Run a virus scan.
  • Use one of the built-in Microsoft drivers.
  • Download the latest version of the product driver from http://www.hp.com.
  • Temporarily close the interfering program for printing purposes. Press CTRL + ALT + DELETE to open the Close Program window. Highlight any fax/answering machine program listed and select End Task. Repeat this process for each program listed that may interfere with the printing process. Try again to print. If printing is successful, the program(s) closed was interfering with the printing process. Uninstall or deactivate it.
  • Remove temporary files in C:TEMP and C:WINDOWSTEMP.
  • Posted on Aug 15, 2008
    • gopinath pasupathy Aug 17, 2008
      download the driver for printer from the hp web site and install it again ......
    Can you make copies on model D7460 HP Printer
    Unfortunately no, there is no scanner bed so it cannot make copies. This printer is primarily for printing photos and plain paper docs. See Amazon's original review on this product in 2007: http://www.amazon.com/HP-D7460-Photosmart-Printer/dp/B000SNP0RW
    NOTE: Our Inkjet411 printer/cartridge support site provides technical tips for for 4000 printer models and includes over 80 videos for do-it-yourself printer remedies and corrections: http://inkjet411.com/
    To refill your own inkjet ink cartridges, refer to our Refill Store Map Locator (over 600 retail store locations in North America): http://www.go2ris.com/#retailpartners
    Alternatively, if you would rather purchase new inkjet ink cartridges, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
    For any additional questions please contact us directly: Inkjet411help@gmail.com
    -Thank you
    Aug 21, 2014 | HP Photosmart D7460 Printer
    The error message is Oxc18a0001. What is wrong with it. I've turned the printer off like it said to do, with no change.
    Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
    Solution 1:
    1. Press and hold "left arrow" key
    2. Press the "setup" key and release both keys
    3. Press and release the "OK" button
    4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
    5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    6. Press and release the "OK" button.
    7. Display should say "Hardware failure status: Clear. Press OK to clear".
    8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
    13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
    15. If the error is still there, or reoccurs the printer is already defective.
    May 06, 2011 | HP Photosmart D7460 Printer
    Photosmart D7460 will not print envelopes from Printshop 23
    u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
    Jun 14, 2009 | HP Photosmart D7460 Printer
    I have a d7460 hp printer and the magenta ink cartridge is empty, but I need to print something very important by tomorrow morning and it won't print. It says that it's "unhealthy" to print in...
    From your printer properties, go to the "Printing preferences" button on the "General" tab. On the "Color" tab, select "Print in grayscale". That should take care of it for ya.
    Apr 21, 2009 | HP Photosmart D7460 Printer
    HP D7460 printing blank pages, no error message
    Just needed to be unplugged (both at wall and at printer) for two minutes. Restarted and it worked fine.
    Nov 22, 2008 | HP Photosmart D7460 Printer
    HP D7460
    I went to the HP online help chat. I was told to take out all the cartridges, wipe a moist cotton cloth on the copper dots on the back of each. Let them dry a minute. Unplug printer cable, and USB cable (if it's not wireless), and unplug from wall. Then hold in power button for 60 seconds. Then I uninstalled HP software and reinstalled. Then I plugged back in the printer cable, and now there are no blank pages. It was quite an ordeal chatting with the rep because it took FOREVER between messages, but all is well now.
    Jun 28, 2008 | HP Photosmart D7460 Printer
    HP Photosmart D7460 won't print
    Did they suggest uninstalling it from device manager, completely and downloading the new vista driver fo your printer off the HP website??? and then installing this.
    Feb 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
    75 people viewed this question
    Ben Johnson
