Question about Kenmore 93862 Top Load Stacked Washer / Dryer
My stack washer / dryer is leaking at the bottom of the tub where the shaft is attached to it. How do I replace that seal?
  • 4 Answers
SOURCE: Tub seal has rip therefore washer is leaking.
noavatar_s.png marklfixit
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Replace the front bellow or front seal, as it may be called. It is an inner tube shaped rubber liner that seals between the front of the washer door and the front of the drum. The cost is about $35.00-$40.00 and you will need the kit as it includes the rubber spacers that are essential to doing the job. The job takes about 1 1/2 hours to complete. It is not hard, but it is dedious and requires some basic skills. Directions included in the kit are helpful. You can do an internet search for the part and many appliance parts shops will carry the part. Do a search for appliance parts in your area and see if they carry that part on line, or you can call them tomorrow. I imagine a pair of strong hands would help as you seperate the outer groove that goes into the drum lip, then replace the spring that holds it in place there.
Posted on Jan 24, 2008
SOURCE: whirlpool duet front loadsher leaks at the bottom of door. how do you replace the seal around the door
On this same machine, I need to replace the boot, but I also need to replace a broken baffle. Is this a very difficult task? The old one seems to have been snapped to the tub.
Posted on Mar 22, 2008
  • 1073 Answers
SOURCE: I have a Model LAT2300AAE
you have to have a maytag spanner wrench
Posted on May 05, 2008
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
dh1200s
  • 335 Answers
SOURCE: replace tub seal in top load neptune
I‘ll be watching your progress real close with the Tub Seal replacement. I’m going to run this machine into the ground and I’m sure I will develop a Tub Seal leak down the road. I have nothing to offer other then the mention in the SM on page 49 about making sure “”When installing a new seal, make sure the sleeve from the previous seal has been removed and discarded.””. Did you purchase or borrow this tool to remove the spinner nut Spinner Tool $25, or is there another way to remove the Spinner Nut? Good luck. Rich
Posted on Jun 07, 2009
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
My appliance is 417.98702891 washer/dryer combo. It leaked water and I was able to determine that the tub seal needs to be replaced. In the process of accessing the tub seal I am encountering difficulty...
yes that has been a issue for all service techs to such as myself and my counter parts have encountered,what i have done is leave inner tub attached to trunion and rotate and lift the tub most of the way with tub attached it adds extra leverage to remove the trunion once most of the way up remove inner tub from trunion and it should come off fairly easy when its most of the way off
Good luck,
Gene
Oh have you remove the two 1/2" hex head botls and tapping plate from side of trunion?
when reistalling there is a notch in transmisson where tapping plate fits into
Aug 08, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
How to change the bottom spin bearing?
Two bearings in that model One in tub will be leaking water if bad. One on the lower end of transmission.which is part of the transmission. Whole tub basket unit must be removed from the case to replace either the tub bearing and seal or the transmission.
Nov 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
My washer is leaking from the bottom as if there is a seal that is worn out. what do I do How do I get the tub out to replace the seal
If this is a front loading machine. The bolts on the drum case have most likely loosened. Remove the rear cover to access the bolts. After tighten the bolts run the machine to make sure this was the problem.
Jul 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Leaking tub seal, slow spin cycle
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Kenmore 93862 Top Load Stacked Washer / Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
