Question about Ryobi Cultivator
Ryobi ry64400 I have a plastic Cam that is partially melted. The part # off the cam itself is 518625 A1. This part is not listed. any suggestions ?
  • Roy Ramirez
    Roy Ramirez May 25, 2014
    I have one also and it melted too. Contacted Ryobi one month after my warranty expired. They said (paraphrased) "tough luck, the guarantee had expired". I'll never buy another Ryobi product again... pure garbage!!!
  • Anthony Murphy
    Anthony Murphy Jun 01, 2017
    shiit product, but we all knew that going in
    New Friend:
It is the biggest piece of JUNK ever sold to the public. Do yourself a favor; Stay away, nothing but problems, never start when you need it, never runs properly and after spend time and money to repair it is still a worthless piece of JUNK.
Posted on Jan 10, 2016
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 57 Answers
I have the same problem. Can't find the cam anywhere so I'm going to make another one.
Posted on Apr 25, 2015
2 Suggested Answers
  • 6468 Answers
SOURCE: ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Posted on Apr 21, 2012
Ryobi ry64400 will not start?
  • Does it have spark?
  • Does it have compression?
  • Is fuel getting into the cylinder?
    More information required. Thank you
May 23, 2016 | Ryobi 10 in. 30 cc Gas 4-Cycle Cultivator...
2003 dodge Dakota 4.7l. High mileage. OBDII throwing a new code everytime I fix something. Crank sensor & Cam sensor - replaced. IAC-replaced. PCM-replaced. Throttle body cleaned. O2...
Have you checked the wiring that goes to both the Crank and Cam sensors? Most of the time the wires are close to a heat source (ie: exhaust manifold) and the plastic covering starts to melt causing the cooper on wires to make contact and thus making engine stop, you will have to take off the protective covering as well as tape around the wires and inspect each and every one. Had same problem with Dodge caravan, it turns out the Crank Sensor plug wires were melted together. Good Luck.
Oct 26, 2013 | 1993 Dodge Dakota
Ryobi ry64400 tiller tines won't move engine runs fine
Apr 17, 2012 | Ryobi Cultivator
Why did my RYOBI charger melt on a job sight counter top and how can they not have a suport number when thing like this happens lost alot on this product why the melt down of the charger ?
I have no idea unless it was possibly plugged into a 220 outlet by mistake, I suggest you call RYOBI direct and ask their service department what might be the cause.
Jan 12, 2012 | Ryobi Drills
HOMEITE HTC12, STARTS AND IDLES GOOD BUT AS SOON AS I GIVE IT GAS,BOGGS DOWN AND STALLS, ALSO WHEN I ATTEPMT TO TURN THE IDLE SCREW, ALSO DIES
Homeite was made with a plastic cam shft when they get hot the melt the lob off the exshost end of cam remove valve come and you will see the damage all you can do is replace the cam sorry not cheap
Aug 28, 2011 | Craftsman 8.50 Torque Rating Dual...
How to time the 12H802 modle lawn mower
This is the B & S 6 HP engine. There are multiple versions of this engine:
12H802-2682-B1
12H802-1922-E1
12H802-3172-E1
12H802-1752-A1
and several others.
The timing is fixed. It is not changeable. Timing can change if the flywheel key is partially sheared because the position of the magnetos' flywheel magnet is rotated forward or back from it's usual position. That is the only way the timing can change.
Now if we are talking valve cam timing. Align the dot holes on the crankshaft and cam shaft gear. The valves should be closed with piston at top of the cylinder.
Thanks for choosing FixYa.
Kelly
Sep 12, 2010 | Toro Garden
I have a Ryobi Cultivator, won't run. New spark plug - RZ7C. What is proper gap for plug?? thanks ront
The correct gap according to my RY64400 operators manual is .025 and the torque is 170-190 inch lbs. The spark plug is NGK CMR7A or Champion RZ7C.
Jul 27, 2010 | Ryobi Cultivator
Husqvarna 2000SL Sewing Machine
The plastic dries out over time, and this is what may have happened. You could probably remove it by exerting a great deal of force, but will most likely break either the cam itself or the part where the cam is inserted. You could try squirting a little lubricant (maybe Tri Flow?) and leaving it for a while to penetrate before trying again to remove the cam. Otherwise, it would be best to take it in to a repair shop where an expert can work on it and maybe replace any parts that are no longer working properly.
Pamsquilt
Oct 10, 2008 | Husqvarna Viking 1
Ryobi Cultivator Logo
504 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
