Recording what are the steps to record on a FUNIA F260LA VCR
  • 5,569 Answers
If you have lost your user guide, you can download it as a .pdf file (Adobe Reader required) from here:
http://www.funai.us/pdf/om/F260LA.pdf
Posted on Aug 18, 2008
SOURCE:
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Can the sansui vcr/dvd combo record vcr tapes to a dvd?
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Mar 17, 2011 | Sansui VRDVD4001 DVD Player/VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
IS THERE A CODE TO SET MY FUNIA SV2000 DVD RECORDER TO WORK WITH MY DIRECT TV REMOTE
Remotes are set to the DVD recorder in the REMOTE. It is difficult to control a DVD recorder with a universal remote except for basic functions. The remote manual needs to list the DVD Recorder or a similar Funai model to control it. Try different Funai codes from your remote book. One might work for minimal stop, play, pause, etc.
Mar 20, 2010 | Funai PY90DG DVD Recorder
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Dvd to vcr?
Plug the DVD connections into the INPUT on the back of the VCR. This is sending the signal from the DVD player INTO the VCR.
If you are familiar with the VHS to VHS, then remove the VCR and replace it with the DVD player.
I hope this helps :)
If the question changes it will send me an automatic message. So if this was not enough info, just let me know! I'll actually hook mine up to record this way then I'll be able to tell you step by step if need be.
Jan 11, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording
Does it record when you are simultaneously watching a program? if yes, then recording circuits are OK. It is definitely a problem of settings. Try doing it again step by step. And before you program for timer recording, make sure that the VCR clock is set for correct time.
Apr 07, 2007 | Sanyo VWM-900 VHS VCR
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Ekse
