Question about Dryers
Hello, my dryer gets hot but is not spinning I think its a broken belt can you inform me of a part number and how to change it? Thanks in advance.
  • Dryers Master
  • 7,482 Answers
Hi armistad...
You will have to find your manfacturer/model/serial number before you will find your parts you need.
When you do you can go this this site for parts or many others on the net.
http://www.appliancepartspros.com/index.aspx
Here is how you will change your belt...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
Replaced broken dryer belt. Drum now spins, except when there is too many clothes in drum. Its like the weight is too much. After I remove several items, it spins again
Hi and welcome to FixYa, I am Kelly.
This symptom sounds like you installed a belt for a 29 inch dryer on a 27 inch dryer. It happens more often than one would think. If you provide your model nunber I can provide you with the proper belt routing diagram around the idler and the correct belt part number.
Thanks for choosing FixYa,
Kelly
May 27, 2011 | Dryers
Dryer gets hot. Won't spin.
Sorry to read about your problem, I hope this helps you out.
you have a broken belt, if your unit is not blowing hot air, you then have a defective motor.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Kenmore 62722 Electric Dryer
My dryer turns on - I hear the noise - it's hot, but it doesn't spin.
Look for a broken belt part number 341241 available on Ebay for a few $$.
Eric
Oct 14, 2009 | Kenmore 62602 Electric Dryer
Have a whrillpool Ler7647Q dryer, it's not spinning
You probably have a broken belt, which is a common problem. If you are comfortable with using a screwdriver, you can change the belt yourself and save the cost of a service call. The belt itself is around $20, and you can get it from local appliance parts stores or from a number of places online.
One site with a very good illustrated procedure for changing the belt is here:
http://repair2000.com/wpoolbelt.htm
If you found this solution to be what you needed, please take a moment to rate it (fixyas are nice!), and thanks for asking here!
Mar 04, 2009 | Whirlpool Dryers
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
My dryer gets hot but does not spin.
Your belt has broken. get the model number off your dryer and take it to your local parts store and they can get the belt. They can most likely show you how to replace it. If not, let me know and i will tell you how.
Nov 20, 2008 | Dryers
Very hot at back, making humming noise, but drum isn't spinning.
the drive belt is likely broken
belt replacements for most models are simple and cheap
have no experience of bendix cannot give exact instructions
Nov 02, 2008 | Tricity Bendix TM310W Electric Dryer
Candy cdc 266
your belt is probably broken, or your motor is bad, the motor and belt not only turn the drum, but also the fan that moves air out of your dryer so if it cannot move, the dryer gets hot and it thinks this is because the lint trap is full
Oct 27, 2008 | Candy CDC266 Dryer
Dryers Logo
168 people viewed this question
Top Dryers Experts
