Question about Mtd 22" Yard Machine Push Mower
Where is the oil drain plug for the mtd 11A-O84EO29
  • Mtd Master
  • 7,482 Answers
Hi dherrin...
Look under the mower housing on the motor and locate a square plug, or maybe a socket screw to remove.
This will be the oil drain.
Free answer...Please take time to rate me
Posted on May 21, 2011
Are all MTD push mowers that begin with 11A basic(ally) the same?
No, when I searched your 11A-020L-765 It brought up a lot of 11A- and some had overhead engines and some did not, had mulching and big wheels and enough that the answer is no.
Mar 25, 2016 | Mtd Garden
Where is oil drain plug on MTD mower
If it isn't on the bottom of the engine (above the blade) then you don't have one. This is not that uncommon. When you need to drain the oil, FIRST- pull the spark plug wire off!!! Then remove the dip stick or filler plug and turn the unit upside down and drain the oil.
May 30, 2014 | Mtd LAWN MOWER PART # 683-04163B FRAME...
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
May 15, 2014 | Mtd 22" Yard Machine Push Mower
How to change oil on mtd(11a-549r729)
i find the best way to change it is to run it out of gas then tip it on the side and drain it from the dip stick tube
Jul 27, 2012 | Garden
Bought 2 brand new MTD 3.5 HP 20 inch cut lawn mowers Model #11A - 020B352 Both mowers run until hot then cut out and will not restart only turn over with a squirt of fuel bulb then stall again. Both...
heres a few things to check, make sure that the oil is not over filled, you might have bad fuel,, and check the spark plugs on both to make sure they aren't fouled by fuel, if so,, clean the plug and regap them,
Jun 02, 2011 | Mtd Garden
How do you drain the oil on a 4.5hp MTD tecumseh engine, their is no oil drain plug.
unplug the spark plug and tip the mower towards the side with the oil filler tube. Place a bowl on the ground to catch the oil. Thats it!
Jun 29, 2010 | Mtd 22" Yard Machine Push Mower
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Jun 12, 2009 | Mtd 22" Yard Machine Push Mower
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Jun 06, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
272 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
