Question about iLO DVD Recorder DVDR05
Will not write on 16x disc
Have a ILOdvdr05 a it says that disc may not be written for it is not in the supported media list.
I have used 16x's but they were Sony +R's , besides this brand I will only use rewriteables which it doesnt seem to matter what brand those are. I only have used the +RW's though.My MU unit likes both but my ZU unit doesnt like th RW's as well. Wants to format and finalize, whereas my MU doesn't insist on finalizing it. Try the Sony discs. I just wait till they go on sale and stock up. IF this doesn't work maybe your unit is failing.
Posted on Aug 17, 2008
What is the correct speed for an LG 6 disc burner ?
Hi!
To have all your discs written perfectly, please allways choose a speed arround one half of the suggested maximum speed.
e.g.: for a CD 52x, somewhere arround 26x, for a dvd 16x, arround 8x
Hope it helped.
Regards,
Bogdan
Aug 20, 2011 | LG Computers & Internet
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
Failed to burn DV disc.Cyberlink Media Show error code 0x0A180001
I was also suffering this problem with Nero 6. To solve your Problem first make sure that the windows you are using that supports your Software if supports, then your Optical Drive may not Write in high speed 16x or 18x, write your files in DVD in little bit slow speed, after doing all this if it gives same problem then Please reinstall your windows you are using.
Mar 08, 2009 | Computers & Internet
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Slow burner
well what you can try is
1.) Cleaning your registery out
2.) deleting all temp files
3.) defragmenting your registery
to do all the above you can use a product know as tune up utilities aviable here www.phazeddl,com type yune up in the search box and search it
4.) defragmenting your harddrive
to to this go into my computer
right click on local disc and click properties.
clicl tools the defrag
5 delete your preftech files
they are located in c:\windows\prefetch
6 empty your recycle bin
7 restart
ensure you have 16x media and your burningspeed is set to 16x
4x media means you can only burn at 4 8x at 8 or below, 16x at 16 or below
if all fails then you need to format and reinstall
dont forget to rate me
Jan 07, 2008 | Dell Dimension 8400 PC Desktop
Dvd playback
Some DVD players cannot play certain types of disks mainly -R discs. Check compatability in the DVD player's manual. Try using +R discs for peace of mind...
Aug 30, 2007 | Memorex (32025618) 25 Pack 16x DVD+R...
I cant record
I posted this in another person's question but it is probably relevant to you as well. This model (which I own myself) is outdated and needs a firmware upgrade. You might get lucky and get one from their tech support. However, I heard they stopped shipping them nearly a year ago. As it stands your recorder can only use DVD-R that records at 4x (or lower) and DVD-RW that records at 1x. Any other media is useless. Since 4x media is outdated, it may be hard to find at a major retailer. Let me know if you have any luck fixing this or finding working DVDs as I have had the same issue myself. I simply cannot find 4x DVDs in the store.
Jun 01, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Disc compatability
Why upset yourself?,my friend, you are going to get the "Electroncoodies" Use the brand [Memorex & Maxell] that works.
Apr 15, 2007 | iLO DVDR05 DVD Recorder
Problems finalizing discs
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Nov 02, 2006 | Toshiba DR4 DVD Recorder
iLO DVD Recorder DVDR05 Logo
43 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
