Question about Initial IDM-1210 Portable DVD Player
The screen sytays on for 1 or 2 seconds and then it goes goes black or blank, but he disc still playing, because I can hear it, I just can not see it.
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Chinese android T04-6 tablet screen goes blank
I'm having exactly the same problem. At first I thought it might be the battery, but if I unplug it, I can still hear facebook alerts, email alerts, etc and if I play around with it (turn it from side to side and press the lockout button repetitively) it will flash the lock screen for an instant - sometimes for a few enticing seconds - and then black. If I plug the charger in while it's powered off I can see the battery icon just fine. The screen WORKS - I just can't see the "desktop". I can't figure out how to do a hardcore reset other than the little pinhole button in the back, but it seems like that just powers it off. I can't see the screen if it gives any options, so I dunno. PLEASE help if you know anything.
Nov 26, 2012 | Tablets & eReaders
After click on the game title. screen goes black
It is normal for the screen to go black for a couple of seconds once you click on the game title.
Although, for some games, the screen goes black for a longer period of time than other games. Another important factor that determines for how long the screen goes black is the health of your disc.
First of all, it is advised that you exercise patience and wait for a couple of minutes before trying anything. During this period of time, the game is trying to load all the necessary files required to run the game.
On the other hand, if the disc you are trying to play is not very clear or has scratches on its surface, this could make the game go on a black screen for longer than normal. So to prevent this from happening, make sure that the surface of our disc is very clean and is free from dust or scratches.
If you wait for about 5 minutes and it still doesn't work, then you can try ejecting the disc to see if it automatically quits the game and returns to the home screen. If it does, this means that the disc is probably bad and you are advised not to try loading it anymore as it could cause damage to your console.
Although you can try resetting the console if it still behaves this way before you confirm that the disc is bad. Below is the instruction oh how to do this.
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hope this was helpful? Please comment for more information and thank you for using Fixya.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
My tv screen goes blank for several seconds while I am playing tapes
Mine does that too when playing VHS. But play any dvd and switch back to vhs and the black screen goes away
Nov 15, 2010 | Toshiba DVR3 DVD Recorder/VCR
Blank black screen
Well your disc is officially garbage because it's for sure scratched. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
Jan 30, 2010 | Ubi Soft Entertainment Assassin's Creed...
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
DVD player won't read DVDs - goes straight to blank blue screen
tried the cleaner disc you can buy one at
best buy or waltmart
Aug 25, 2009 | Initial DTV-172 17 in. TV/DVD Combo
Initial IDM-1210 Portable DVD Player Logo
Top Initial Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
