Question about Dryers
The power company shut off the gas to my home. When it was turned back on I could not get the drier to re-light. I have a Kenmore 87573 100.
  • 413 Answers
There is air in the gas line. If you are able, you can loosen the gas line behind the dryer (dryer off) and let the air bleed out of the line for 10 seconds or so. Tighten the gas line back up after you bleed the air out, use a little bit of soapy water to check for leaks where you tightened it, and then try your dryer again. You may have to do this a couple of times.
Many times, if the dryer tries to light enough times, it will eventually bleed the air out on its own. It may take several times trying though. Hope this helps
Posted on May 21, 2011
The drier is not getting hot
If it's electric and you do not have the knowledge to be working with 220 vac power I would suggest you call a repair person to come and look at it. It can be a tripped breaker, check you breaker box and shut off the drier breaker and than turn it back on making sure both sides lock on. Other than that, you can have a bad heater element or a bad timer. The most common would be a bad heating element. The element is normally found either behind the drum or down below the drum area and can be accessed by removing the lower front panel. Gain access to the element or open the dryer door and start the dryer by holding down the door switch and push the start button. If it is behind the drum you should see it glowing by looking inside the drum as it's running. The same is true for the element that is underneath the drum...remove the panel and start the dryer, you should see a glow from the element box. If you do not see a glow, unplug the dryer and check the element for a burned connection or break in the element wire. If you have a gas dryer, check that the supply is on, check that the dryer is plugged in and if so equipped check that the pilot light is lit. If the dryer has electronic ignition, you should hear a clicking noise when you first start it up. No noise, no ignition! If the pilot light is out follow your instruction book and relight the pilot or call your gas company for help!
Mar 05, 2015 | Kenmore Washing Machines
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
Just hook up drier had to change power cord getting 240 to the drier light is on but drier do not star up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Kenmore Dryers
Will not light
Have you removed the burners covers and top to see if the PILOT LIGHTS may have blown out? Hold a stick match or fireplace match (long stick) down in the area of the circular burner after turning on some gas. The burner should light and the pilot light should stay on as well. You local gas company provides service for this type of problem. Call them and have a gas company representative make a home call (free service) in most areas.
Oct 08, 2010 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
Gas dryer not heating up
it probably has a igniter, not a pilot light that lil hole is a check sight hole, close the door and set the drier to start , within a few seconds you should see a glow plug light up, if not,, check the main fuse in the back of the machine,, this is normally caused by a lack of flow for the drier vent and over heating
Aug 02, 2010 | Kenmore 63942 Dryer
Drier shuts off after a few minutes
Sounds like you have thermostat problems, try to replace your thermostats
Sep 25, 2009 | Kenmore 63942 Dryer
Is gas turned on with pilot light or electronic?
No pilot. Unplug the power to the unit and it cannot run/ignite. There is a shutoff on the valve behind the front panel if you want to turn off the gas supply without moving the dryer.
Jun 28, 2009 | Kenmore Dryers
I have a kenmore gas dryer 110.74832400 doesnt heat
You stated you checked all lints roblems. Just to make sure. Did you remove the lint catcher completely on the inside? If not take that off and clead the lint out of the inside of the duct. Also lint can build up inside the lint duct on the rear of the drier and in the duct going outside of your home.
Jun 03, 2009 | Kenmore 75962 Gas Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
