Question about Metrologic Instruments 9520 Voyager
I have a problem in the bar code is 9520 and I hear St read the barcode, but the numbers do not appear on the program or read on the screen Please Almsaadp
bluegreenash
  • 661 Answers
SOURCE: letter G appear at the end of barcode
you have a "suffix" programmed into the barcode scanner. this is a common feature and allows for auditing (like a user signature) these can be removed, The code book should have pages of option programming barcodes, in which you should be able to find a section on programming prefixes and suffixes, there should be a control barcode which clears all suffixes. This should solve your problem
Posted on Sep 07, 2007
bluegreenash
  • 661 Answers
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Posted on Oct 04, 2007
tcward
  • 4 Answers
SOURCE: I can't programmed my IT3800LR
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
The factory reset bar code is on printed page 4 of the PDF document.
Posted on Mar 06, 2008
tatsuto
  • 13 Answers
SOURCE: barcode scanner Symbol LS2208
I had the same problem with LS4278, you need to configurate your keyboard and scanner in the same regional and language options
Posted on Oct 20, 2008
SOURCE: scanner shows number but won't scan to computer
If you're sure that the barcode is correct then ignore the following.
Otherwise, download a free barcode font and install.
1. Open up wordpad .. and type any number say "12345", and then convert it by choosing the barcode font.
2. Print out the barcode (usually at least 26pt)
3. Leave wordpad as the active window and scan the barcode
4. "12345" should be inserted into the wordpad document.
Now you know that it works.
This should work on the default setting of most scanners.
Posted on Mar 25, 2009
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
We recently received another 9520 from Honeywell to replace a faulty one. For the non-tekkie, how do I configure it for use with library scanning for books?
Bar Codes The MS7120 can be configured by scanning the bar codes located in the MetroSelect® Single-Line Configuration Guide. This manual is available for download at http://www.honeywellaidc.com/site.aspx/na/en/product_center/product_support/?category=5&product=297
Please let me know if you need further assistance
Kim Ganoe 800.933.2839 x251.
Mar 23, 2010 | Microsoft Metrologic MS9520 Voyager...
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Mar 27, 2009 | Metrologic Instruments 9520 Voyager
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Jan 19, 2008 | Metrologic Instruments 9520 Voyager
Oct 03, 2007 | Metrologic Instruments 9520 Voyager
Letter G appear at the end of barcode
Sep 04, 2007 | Symbol LS2208-1AZU0300S Handheld
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Metrologic Instruments 9520 Voyager Logo
119 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
William Robinson
William Robinson
Sandeep Kumar
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
