Question about Asrock K8UPGRADE-NF3 Socket754/nForce3 250/SATA/A&L/ Motherboard (MOTASR12)
I have k8-upgrade-NF3. I tried to connect two SATA CD-ROM to SATA1 and SATA2 ports but the computer restart constantly. The domada is: i can connect cd-rom and cd-burner on SATA1 and SATA2 matherboard? We need to change something it bios? Thanks in advance for your help
  • 92 Answers
You need to change the BIOS setup. Go to the booting menu change the arrangement of your hardware.
1.Primary Disk (Hard disk) 2.CD/DVD ROM 3. Floppy 4.others
then save and exit. Your PC will reboot and MUST detect first your hard drive to proceed to your desktop..
I hope it will help you..
Posted on May 21, 2011
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
1.
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
What are the correct connections for harddrive to motherboard??? on a Acer am5100-U5301A AMD Athlon 64x2 dual core. can't find connection diagram
It depends. Some (older) disk-drives use "IDE" (also called "parallel-ATA") 40-pin connectors.
Some (newer) disk-drives use "SATA" (also called "serial-ATA") connectors.
So, look on the motherboard for "IDE1" and "IDE2" ports, and/or for "SATA1/SATA2/SATA3/SATA4" ports.
Mar 18, 2011 | Acer Computers & Internet
Some one give me this DVD burner Sony DRU-540A ..would it use IDE or Sata...It did not come with any cable...what cable i need to get?
If you look on the back of the burner, you will notice either a slot with 39 pins or a small black like plugin. The 39 pins would be for an IDE plug, and the little black pin would be for a sata cable. Simply go to the nearest Radio Shack, Best Buy, or computer hardware store and get the appropriate internal cable. Just advise the store attendant in that area to advise you were such cable is.
These are very simply to plug in, simply plug in to the back of the cd-rom, and plug into the motherboard with a similar plugin on the motherboard. Make sure the plugin on the motherboard states it is Sata, on the motherboard it will have something printed near it with Sata1 Sata2 or something similar. Put the CD-ROM in the closest bay, and plug in appropriately.
Dec 04, 2010 | Sony DRU-540A DVD±RW Burner
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
Can I use a SATA2 HDD for P5GL MX?
just like usb1 and 2, the sata2 harddrive will simply clock down to match the speeds of its port. the connections for both types are identical so there are no possibilities of problems...other then the motherboard saying "nope i cant read that", which most likely wont happen.
ohyeah...ram does the same thing too.
but honestly, if you're using a mobo thats only sata1 and you've got the dough for a new 1tb harddrive, you should consider upgrading your motherboard first...much better money spent
Apr 26, 2009 | ASUS P5GL-MX Motherboard
P4VM800 SATA HDD Problem Plz Help me!!!
Check your user documentation for the hard drive to see if it has a user-accessible jumper that will switch it to 1.5Gb mode. I know that Seagate/Maxtor drives have a jumper they refer to as Force 150 and Western Digital calls their jumper OPT1 Enabled. If this option exists with this hard disk, it should solve your problem.
Mar 21, 2009 | Asrock P4VM800 Motherboard
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Bios settings
at bios settings choose auto detect for secondary master and secondary slave.
one burner must be master and the other one is slave jumper settings. all burners must be place at secondary drives.
Jan 24, 2008 | Adaptec (ASH-1233) (ASH1233) ATA...
Computers & Internet Logo
135 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
