Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
The brushbar stops when I pull the vacuum back towards me. It also stops if I lift the vac off the floor.
4 Suggested Answers
SOURCE: Brushbar has stopped spinning on Carpets
Because the brush bar is electric, it automatically shuts off if you get something stuck in it to keep the motor from burning up. you have to remove the item and then push the small reset button on the side of the brush bar<!-- from fixya rte -->
Posted on Aug 12, 2010
  • 19 Answers
SOURCE: the brushbar stops when the
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
See full details with photos at: http://www.bajwa.net/?q=node/3
Posted on Aug 09, 2011
SOURCE: DC15 Brushbar Problem. Intermittant operation of
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not jammed. Seems like a loose connection somewhere but where ? and what
Posted on Sep 14, 2011
My brush bar has stopped - how can it be made to rotate?
http://www.dyson.com/support/dc40/dc40-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/check-the-brushbar-video
Apr 01, 2015 | Dyson DC40 Animal Upright Vacuum -...
Bissell proheat 7901-9 the brushbar only turns when handle is completely upright. When I lean handle back to move machine, brushbar stops rolling. What could be the problem?
There is a lever in the machine that lifts the brushes when it is stopped. The lever can slip out of position. You have to take it apart to get to the lever.
Jul 08, 2014 | Vacuums
Brushbar button won't fully depress - can't turn OFF the brushbar.
Here is how the switch assembly should go together:it may need a new switch
Jul 22, 2013 | Dyson DC15 Animal Bagless Upright Cyclonic...
I have a dyson DC23 and the turbine head will not turn anymore can anyone help on how to reset. I have cleaned it and there is no blokage its just stopped? Please can someone help
  • Pull the plunger into the ''out'' position for vacuuming carpets.
  • For vacuuming hard floors push the plunger into the ''in'' position to stop the brushbar spinning.
  • Refit the tool onto the machine and test.
  • turbine_plunger_in_out%20jpg.ashxHas this resolved the problem?
    Dec 05, 2012 | Dyson DC23 Bagless Canister Cyclonic...
    My dyson 24 .....brushes will not stay on when vac.ing carpets
    Your DC24 is equipped with a sensor which shuts off the brushbar if something jams it. Once you've checked the cleaner head for obstructions, and removed any threads or hair from around the brushbar, you should be able to reset the machine as shown in the video below.
    You may also want to refer to our online Support guide:
    http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
    This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Dyson Online Customer Support
    Apr 03, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    The brushbar stops when the vacuum is pulled back -- works some, doesn't some. DC 15 4 yrs old,on 6th brushbar.
    Jul 09, 2011 | Dyson DC15 All Floors - The Ball Bagless...
    DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not...
    Jun 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
    Dyson DC 25 Ball - no power to motor
    Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
    Mar 14, 2010 | Dyson DC25 All Floors Bagless Upright...
    Dyson vacuum brush roll doesn't turn
    The brushbar should only turn when you meet two conditions:
    1) When you step on the front of the machine and pull back on the handle (recline the machine in other words)
    2) The dial is set to CARPETS
    The brushbar shouldn't turn at all when it is set to the BEAR FLOORS setting.
    To rectify the problem - call the Dyson Helpline so that they can refer you to an authorized dealer in your area - the repair dealer will inspect the dial and figure out why the functionality seems to be switched. They'll be able to fix it for you.
    Mar 19, 2009 | Dyson DC07 All Floors Bagless Upright...
    Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
    Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
    Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
    Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
    254 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
