Question about Watches
How to remove a watch from the band that is attach to it
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: watch band link removal
Find out here in my tips.
Posted on Feb 04, 2010
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
      Making the Band Shorter
    1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
    2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
    3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
    4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
    5. Making the Band Longer
    6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
    7. Step 2 Push the pin out so the link is detached from the clasp.
    8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
    9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
    10. Step 5 Repeat this process if you need to attach more than one link.
    Aug 14, 2010 | Citizen Watches
    The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
    mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
    Jul 21, 2010 | Seiko SGF204 Wrist Watch
    Replacing watch band on pathfinder pas410. can't get pins out to replace band.
    Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
    Rate me, plz.
    Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
    I need to shorten the metal link watch band of my Casio Model 2747 watch.
    I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
    I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
    Thanks,
    Steve Zansler
    Dec 31, 2009 | Casio Watches
    How to change a watch band for shark freestyle model 788
    Jim, you still need to remove the pins that the band is being held on with. You can use a small jewelers screwdriver to push them in.
    However, I am having a tough time getting my new band on!
    May 13, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio G Shock (Model G2300)
    you have to remove the pins located under the band
    Feb 26, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Watches Logo
    46 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
