Question about Linksys Wireless-G WRT54G Router
I have used my router with no problem on my old computer system. Now that I have a new system I've loaded the Cd and double checked to see if it is connected correctly and an error comes up that it does not detect the router? What else can I check?
  • 2,794 Answers
You only need the CD to setup the router. All you have to do is plug the wire into the router and make sure the network card is enabled on your computer. If you are going wireless, goto the network settings in your control panel, turn the wireless on by the keyboard if you have a notebook and make sure it's enabled in your network connections. Move the mouse over to the wireless and select scan for networks. Linksys is the wireless name by default.
Posted on Aug 15, 2008
I have a Belkin wireless router- I haven't used it in a while- I have a new laptop and it keeps asking for a security code. I've tried all the numbers on the router and even tried with the 00in...
if you had a cd that you installed it should be in the program.
Look for a Belkin program on your computer, the password should be there, you can change it after you've found it.
Sep 23, 2011 | Belkin N150 Enhanced Wireless Router...
I have an older (maybe 4 or 5 years) used WRT54GS and I am starting to have problems with the wireless internet connection with my mac book that I have had for a month. Before it used to work fine, no...
WRT54GS may be more reliable router and you can continue to use it. Try power cycle first check cables! If no improvement you can reset! that will bring it factory default!
Other important matter is check the firmware upgrading firmware is a good solution for these kind of problems!
Currently available routers are much better if you are willing to get a new router N router is the way to go! They wider area coverage and faster network speeds!
good luck!
Sep 11, 2011 | Linksys Wireless-G WRT54GS Router...
I have an old wannadoo live box on orange worked fine until I moved home. Orange have confirmed that internet has now been set up at my new address and I kept my old phone number. The LAN into my...
i assume you have DSL connection through phone line . double check the cables see if they are connected properly betwee the modem and router etc ..if its all connected then reset your router by pressing littile tiny button at the back of Router and apply new WPA2 password and try connect .
May 12, 2011 | Computers & Internet
My 13 year old son laptop need be reset like new
There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Wireless Belkin N300 will not stay connected to my HP Pavilion
It might not work Because your laptop should XP service pack 2 Or above
You can try upgrading your operating system before throwing your router out of the door
Jun 07, 2010 | Belkin Wireless Surf Router (F7D2301)
I am unable to set up an internet connection with my wireless neatgear router on my new dell desktop. The router, model DG834PN works fine on my old computer, but when i try to load the network adapter it...
use your other computer to goto netgear.com look for downloads and find your adaptor. you may have an older adaptor that is not suitable for vista or windows 7. it may need an updated driver. so download the appropriate driver for the operating system to the working computer, and burn it to a cd. then you should be able to run the disk on the new computer. we at charter had this issue when vista came out, our install disks didnt have the right drivers. you just need the right drivers for the adaptor vs operatin system.
Nov 17, 2009 | AbleSoft Teacher's Toolbox 4.0...
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
Change of printer, i lost the CD
hi
-you may visit this website to download drivers
for your computer
http://download.famouswhy.com/hp_deskjet_f4180_all-in-one_driver/
cheers
Oct 09, 2009 | Office Equipment & Supplies
Conect the router?
1. Unplug your DSL modem’s power supply.
the old router and plug it into the gray port on the new router.
port on the Router.
modem to start up.
4. Locate the CD in this guide and insert it into your computer.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Computer
Hi Diviola, you have no choice but to buy a CD-ROM drive. They are not as expensive as you might think. You're windows CD can format the hard drive in you're computer before installing windows. Some people can use a USB memory stick but in order to copy the windows CD software to the memory stick you'll still need a CD-ROM drive. A 2GB or 1GB memory stick will cost as much or more than a CD-ROM drive. Please click on the link to see some prices for a standard CD-ROM drive.
http://www.zipzoomfly.com/jsp/ProductList3.jsp
& here.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3287198&CatId=87
The link above is a CD-ROM drive & can also make CD-RW's (RW stands for re-write).
You can replace you're CD-ROM drive you're self. Just do not disconnect the cables from you're old CD-ROM drive untill you have the new drive. Connect the cables to the new drive (one at a time) as you disconnect them from the old CD-ROM drive.
Double check that the cables are tightly connected before you power up the PC. Load you're windows CD into the new CD-ROM drive & when you start you're PC up windows will start to load.
When you receive the new CD-ROM drive & if you need help connecting & running anything. You can come back here & ask questions. I'll help you through this.
Luck!
Mike
May 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
