I have a motherboard which has a problem of no power at all. pls provide me the method to find out which component of motherboard is dead.e.g. mosfets, smsc , winbond or any other issue. it is ga81845gvm
  • 1,381 Answers
Hi duggalcomput
Most probably a PSU issue if you are sure all power supply connections and power switches are under control and the drives and fans are also not responding when starting your pc .
A new PSU is really nor expensive and easy to replace . Check the fuse before all .
Best regards ,
fanaudi .
Posted on May 21, 2011
Acer ms2220 notebook is dead.want to know which component in the mother board is faulty
If the motherboard will not power up and will not charge it is either the AC adapter or the DC power jack on the motherboard. The DC power jack failing is quite common and it can seem like the whole motherboard is dead when only that is causing the issue. Search on google for DC power jack replacement and they can usually get you going without trouble.
Apr 03, 2010 | Computers & Internet
Motherboard DV1000 DA0CT3MB6G6 dead or faulty
I will provide you the part number for the motherboard, you can find the motherbaord online. It will be costly, try searching for cheaper price.
393656-001 : 915GM
393655-001: 910GM
Feb 07, 2010 | HP Pavilion dv1000 Notebook
MOTHER BOARD NOT POWERING ON
I want you to try first swap the power supply box  of the PC if no change ?
go to the CPU socket remove the CPU check if any component is burnt that area if ok put a new CPU  then on it .
If still behaving the same ,then the mother board is bad get a new mother board
Good luck
Oct 01, 2009 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Apple xserve g4 dual 1ghz won't power on
Sorry man, I went through this with my Dual 2GHz G5...your logic board is dead, computer wont work till you replace it, and even that is no garantee your RAM/CPU's are in working condition, logic board failure tends to eat components like that.
Jan 23, 2009 | Apple (R) Xserve(R) G4 Server Computer...
Dead Toshiba A100 laptop computer
In order to replace the power jack in your laptop you’ll have to remove the jack from the motherboard as I explained in the previous post: Replacing DC power jack.
While removing the jack you can accidentally pull out the internal copper coating (I’ll call it a sleeve) from the inside of the “+” terminal as it shown on the picture below.
The internal copper sleeve has been removed and cannot be installed back. If you solder the power jack back on the motherboard without this sleeve it might work but the connection between the “+” lead and motherboard will not be reliable.
In the following guide I explain how to fortify a damaged power jack connection. You can use this repair technique in some laptops with similar power jacks.
Laptop is dead. How to troubleshoot the problem.In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack. Check out thisguide for fixing laptop power jack.
Jan 12, 2009 | Computers & Internet
PC CHIP Motherboard
Now by PC chips do u mean CPUs? because if so then yes your motherboard is dead but im not sure if it would be BIOS related. There should be a battery somewhere, one like a wristwatch but bigger and flatter on the motherboard, look for it and replace it and test if it works, otherwise it is most likely your motherboard is dead and you need a new one. There is a way of fixing the BIOS if that is the problem. Its called Force Flashing BIOS. I Don't know too much about this but apparently its not hard. Google It and see what you come up with
Hope This Helps
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Mother board dead for all
pleace help me..i need a audio driver for p4vmm2 audio driver
Oct 15, 2008 | EliteGroup P4VMM2 Motherboard
Toshiba Satellite A135 is DEAD!
Open the back panels, blow out EVERYTHING and remove and re-insert everything. You could just have dirty contacts somewhere. The dust from the fans also travels around inside the computer.
Sep 08, 2008 | Toshiba Satellite (K000004080) Motherboard
Power problem( it not switig on )
depends, check to see if you have the power switch pin-outs from the case to the motherboard properly connected, they might be reversed.
Aug 12, 2008 | Asrock P4I45GV R5 Motherboard
Laptop
pls if ur motherboard dead if it is in warrenty pls exchange it
Jul 06, 2008 | Intel Motherboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
