Question about Zenith P60W26 60 in. HD-Ready Plasma Television
I have a Zenith P60W26. It has vertical lines starting from the top working down the screen. Some are red some are green It started with one, now i have 6 or more. They are starting to appear on the right side now. They change in appearance (color) as the image changes, but they are always there regardless of the input source.
  • jim_mcewa702 May 21, 2011
    thank you for the input. how would i be able to get a schematic for this unit? also, would you be able to furnish me with a block diagram that would show me the relationship of the particular boards to each other. i would like to work "down stream or upstream" in trouble shooting the problem. you mentioned that i should start with the power-supply and base most of my diagnosis on looking for visual signs of poor solder connections. are there any board mounted components that would be responsible for these symptoms? where would i go to obtain sparring boards?
  • Zenith Master
  • 2,098 Answers
Hi Jim,
This is very common faults in plasma tv. Bad news because this kind of symptoms has a lot of parts that are going to consider which was gone to malfunction. The boards most likely to fail are the control board, sustain boards, and the power supply board. They are chain for processing the image and feed to the plasma panel. First the unit must isolate from loose connections and bad solder joints because it will produce same symptoms. All the cable connectors must be pull-out and then re-insert and ensure the connections. Power supply board is prone from bad solder joints (cracked/dried/cold solder) because this is the warmest/hard working among the boards. This is hard to spot, I would advice you to work in the brightest area or used table/portable lamp and magnifying glass and re-solder it on the board.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician or send it to reputable repair shop.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 21, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva May 21, 2011
    thanks for the response, I saw some of your board at this LINK1 and LINK2. I've been checking my other link to have a copy of the service manual to guide you fixing the unit yourself.
  • Jdvillanueva
    Also check for bad filter electrolytic capacitor in the output of the power supply. It will dropped the supply voltage and will disable the boards loaded to it. Sometimes it bulged/dome at the top.
  • Jdvillanueva
    "Zenith P60w26 Service Manual" . I will take a sleep by now its already 11:00pm here.
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green and red a little blue everything is doubledup lines droop down from the top everything is dropping to the middle
CONVERGENCE PROBLEMS. WILL REQUIRE PARTS REPLACEMENT. POSSIBLE VERTICAL DEFLECTION FAILURE ALSO
Dec 27, 2009 | Zenith R57W46 57" Rear Projection...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Vertical line in centre of my zenith plasma p60w26 tv
I also have this problem, but with 2 black vertical lines on the right side of screen half way through. Lines disappear from time to time but reappear. Is there anything I can do to get rid of them. Help me out please
.... Thank You.
Jan 02, 2008 | Zenith P60W26 60 in. HD-Ready Plasma...
Zenith P60W26 60 in. HD-Ready Plasma Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
