Question about Refrigerators
NEED TO FIND DOWNLOADABLE EASY MANUAL FOR SAMSUNG RSH1NHSW SIDE BY SIDE FRIDGE FREEZER CAN YOU GIVE ME WEB LINK
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
SOURCE: refrigerator not cooling
Open the panel in the freezer, and take a hair dryer to the frozen coil.
Posted on May 13, 2008
  • 9 Answers
SOURCE: SAMSUNG RS20CCMS
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Posted on Sep 06, 2008
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
Jun 10, 2014 | Samsung RSH1DTMH American Style Silver 524...
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Freezer not freezing, moves from 8 degrees to 34 degrees. Fridge keeps constant 40. Someone said it was frost temp sensor? Cant even get into interior back pannel to replace now I have the part.
There are 2 thermistors for frost and 2 for temperature....Fridge and freezer compartment have one each.
Access to the thermistor sensors are from the inside of the fridge and freezer. You have to remove the shelves, trays and the inside panels to get at them.
The manual will show you how.
There are diagnostics you can run that will tell you which one is in trouble.
There are sensitive voltages that may be required to measure. So from a tech point of view you may need someone with electronics expertise to do the measurements.
The procedures and various measurements are too lengthy to tell you but I will give you the link to the service manual PDF and you or someone can do the diagnostics...The Manual is 87 pages long. Can you imagine a fridge needing that much documentation.
That said. I have the same fridge and have fought 3 different problems...not fun....
here's the link...
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Make sure you unplug the fridge before you go taking things apart...
Good luck
Maytag owns Samsung
Dec 29, 2009 | Samsung RB215LASH
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge is not level - it is higher at the front than at the back.
We had the same problem when our was delivered last week. I spoke to Samsung customer services.
They said the roller in the middle of the front is not meant to be there permanently. It is just a transport roller and should be removed once your fridge freezer is in place.
To remove it:-
- unscrew the two white plastic feet at either side of the front until they touch the floor.
- then place a flat end screwdriver in the slots in the feet and continue to unscrew them. They will start to lift the front of the firdge -freezer up until the front roller no longer touches the floor.
-keep doing this (a little bit each side at a time so the fridge -freezer stays level) until the roller is about 15mm off the floor.
- then get a small flat spanner and remove the two small bolts on the metal plate that holds the roller to the bottom of the fridge-freezer.
Once these bolts are removed the roller and plate will drop to the floor and can be removed.
Then using the screwdriver, screw the feet back in until the point when the front of the fridge-freezer is level with the back.
The whole process shouldn't take you longer than 15 minutes.
I asked Samsung why this isn't included in their instruction manual and they couldn't give me an answer which I thought was poor.
I do wonder how many Samsung RSH1 fridge-freezers are out there with the front roller still attached!!!
Oct 25, 2008 | Freezers
Filter indicator on samsung side by side fridge freezer is on
2 places filter can be top left upper corner of fridge or behind the fridge with a little longer filter type
the smell could be the filter but i would pull all drawers and shelves and i would check for mold also the possibility of water leak behind panel of water spout that has molded over this smell you could never forget cause smells like old gym socks
Apr 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
