Question about Sony Televison & Video
I WANT TO BUY DIGITAL TUNER FOR MY TV SONY KDL-46V3000 AND WHAT THE RIGHT ONE.WHEN PRESS ON REMOTE CONTROL THE BUTON DIGITAL SHOWS CHANELS BUT YOUCAN GET IT.THEY WANTTO BE CONECTED
  • 1,238 Answers
Good day!
If you have encountered that problem you have to do first is to contact your digital cable provider.
or also try the aerial connection.
If the problem persist it could be the tuner.
Try this link to buy a new tuner that fit to your TV model.
http://compare.ebay.com/like/120639818585?ltyp=AllFixedPriceItemTypes&var=sbar
buy it for only $34.88
Thank you
Posted on May 21, 2011
My sony bravia kdl-46v3000 was giving me three blinks i change the main board now i am getting eight blinks
try this.
Turn on the TV. While holding down V on the remote control, press POWER
on the TV. (The TV will turn itself off, then back on again.) Release V.
WARNING: The Reset will clear all of your customized settings
Sep 27, 2012 | Sony BRAVIA KDL-46V3000 Television
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia KDL-46V3000 turns off with blinking front light.
Sounds like the power supply may be failing. Count the beeps next time, that will give you the error code.
Jun 18, 2017 | Sony BRAVIA KDL-46V3000 Television
Image does not position well
Your Sony TV remote has a "WIDE" button. Press this a few times in a row some that you understand it's operation. Then pick a mode (I would recommend "FULL") that fits your needs. I hope this helps.
Mar 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
AT&T uverse remote code for Sony KDL-46V3000
hi! i have here a couple of codes for your SONY tv, just try them 1037, 1128, 1137, 1178, 1215, 1216, 1218, 1219, 1220, 1221, 1250, 1251, 1316, 1318, 1330, 1347, 1413, hope this helps!!!! goodluck!!!
Nov 16, 2009 | Sony BRAVIA KDL-46V3000 Television
Vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
Oct 19, 2009 | Sony BRAVIA KDL-46V3000 Television
Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Feb 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
