Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
While printing a label, a sticky label got stuck around the paper feed and in removing it the paper out sensor head came loose. i tried to replace it but I get a paper out light on. Which way up should the head be?
  • Official Brand Answer
  • 3,344 Answers
It sounds like you had a paper jam and when you tried removing it, something from the printer got loose/broken. It would be best to contact Lexmark technical support for assistance.
Posted on Jun 01, 2011
Lexmark E460dn paper stuck
If the paper is stuck on the fuse, I am assuming you mean the fuser. You will probably have to replace the fuser. You can remove the fuser and try to remove the paper and then reinstall the fuser. Could be a sticky sensor as well.
Apr 12, 2014 | Lexmark E460dn Laser Printer
HP LaserJet Pro 300 M375nw keeps saying paper jam in drawer 2 but there is no paper anywhere.
My problem was the rollers at the top of the printer where the paper feeds out of the unit. I had printed some labels and some sticky material from the labels stuck to the rollers and metal fuser unit. I cleaned off the sticky strips from the rollers and fuser roller and the unit works fine now. You may have to let the printer cycle several times so it turns the rollers so you are sure to remove all the sticky stuff or paper. I also used a can of the compressed gas to spray out all the dust, paper and sticky stuff after I scrapped off with envelope opener.
Jul 24, 2012 | HP LaserJet Pro 300 M375nw All-in-One...
Canon ix4000 printer. Paper jam caused by sticky label, came off backing, stuck to roller. Normal paper jam cures not effective.
This seems to be fault in the transport of the paper in the rollers. So since you have used adhesive sticker printing, it is possible that some glue has got clogged into the rollers.So use a good clening of the rollers using methyl spirit. also check to see asthere can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Mar 30, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
We have a dymo labewriter that has a label jammed in the roller. Part of the sticky part is stuck on the roller. Cannot be pulled through. What to do?
LabelWriter Label Jam
  1. Unplug your LabelWriter.
  2. Remove the spool and labels.
  3. Remove the face plate.
    • Note: The face plate is the piece with the DYMO name/logo.
  4. Using the paper release lever on the left side of the printer, move the print head away from the feed mechanism.
  5. Straighten out a paper clip and GENTLY cut away at the label caught in the printer.
  6. Using caution, begin removing the label.
    • Note: We recommend using tweezers to remove the jammed label.
  7. Reinsert the face plate back on the LabelWriter. If you need assistance reinserting the face plate:
https://dymo.custhelp.com/app/answers/detail/a_id/278/session/L2F2LzEvc2lkL2ZVOGZXRmlr
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 28, 2010 | Dymo Office Equipment & Supplies
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
Paper jammed, upon removing paper, paper does not
My CX4800 developed the same problem. It was an excellent machine until then. I tried everything I could think of, and finally decided it must be the rather large feed in rollers at the right of the paper bin (one below and one above the paper) that had worn too smooth to pull the paper in. It works fine if I will give the sheet a "push" when it starts to go down
If it doesn't feed any paper at all (even regular sheets) and you already have tried loading just 1 sheet it still doesn't feed it...means that it is an issue with the hardware itself particularly the paper sensor. This is usally caused a paper jam and clearing out the jam in the incorrect manner. If your printer is still within the 1-year warranty from the date of purchase, I recommend that you contact Epson technical support for a replacement or service center referral in you area if beyond warranty period. They may also provide you with other options suitable for you needs
You probably have a sticky paper feed sensor or a small bit of paper stuck under or around the sensor. Unfortunately the sensor is really difficult to get too without pulling the machine apart, but can be done if you take your time. The sensor is visible looking into the machine just adjacent to the printhead when it is parked behind the metal support
and if u have any lines on the paper when you print, it is most likely paper fluff or a hair struck under the printhead. Put a small soft cloth on the paper feed platen and run the printhead over it gently. Turn the printer off and then open the cover. Turn the machine on and when the printhead moves off the cleaning station, pull the plug out (this won't hurt the machine). then place the piece of cloth on the platen and slide thge printhead over it. Don't force anything. There will be mild resistance but not much.
If this seems too much, then a service agent might be your best choice but expect to pay around $50-$60 for the job.
May 02, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Not printing ink
The print head needs cleaning. Use a swab and alcohol to clean it. If that doesn't solve the problem, then the heater in the print head needs replacing.
Sep 07, 2017 | Dymo RhinoPRO 3000 Thermal Label Printer
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Paper Jam
You may have left some debris in the printer, or there could be a piece of debris blocking one of the sensors. Try to reinspect printer and clean it out throuroughly. If it still isn't printing, try removing toner and replacing again. If neither of those work buy a used laser printer on craigslist and save yourself the trouble.
sorry if this isn't great news. service may be worth it, try a small computer store rather than a larger store.
Dec 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paper Out Sensor Not Working
try pressing the load/eject button and switch off the printer then switch on again
Jul 25, 2008 | Epson LQ-1050 Matrix Printer
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
