Question about Bulova 96R000 Watch
Just got as a gift. Tried to set time, date etc. and the watch doesn't work? Do you have to screw the post in the 1 position, or is that just to set? Help.
3 Suggested Answers
Accelet
  • 5 Answers
SOURCE: how do I set time and date on my automatic Steinhausen watch?
moz-screenshot.pngyou can refer to the customer service on the Steinhausen homepage:
http://www.steinhausenonline.com or call free: 24/7(800)208-2607. they can offer you the best advice.
Posted on Jan 20, 2010
mcdevito75
  • 1970 Answers
SOURCE: i'm tryng to set the date without changing the day
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Posted on Jul 04, 2010
I bought this cote d'Aazur watch on the allure of the seas. i got it and the person set the time. but the date was wrong. so i turned the knob all different ways and couldn't get the date handles...
Watches that are set via the crown wheel (winder) have three positions;-
1) the home position;i.e. fully in against the case.
3) Fully out; the watch stops and the time can be set.
2) half way between 1) & 3) .This position is used to set the date (In one direction only) and the day (the other direction).
Sometimes there is a soft "click" when position 2 is reached but if not just try to find out exactly where it is by trial and error.
Jun 21, 2011 | Watches
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
Jul 04, 2010 | Bulova Watch
How do i set date and time
NOTE: NEVER EVER set the date between 7pm and 2am or you will damage the watch!! The crown is screwed down to make it waterproof. Start by unscrewing the crown by turning it counter-clockwise until it pops out slightly. That is position '1' which is used for winding. Pull it out two more clicks to position '3' and set the time by turning the crown clockwise. Turn it past midnight at which point you will see the date change and continue turning till you get to the right time. If you're setting the time to a point after noon, be sure to go all the way past 12 noon before setting the time or the date will change at noon instead of midnight. If the time is before 7pm push the crown in to position '2' and turn it to set the date. When you are finished push the crown all the way in and turn it clockwise to screw it down.
Apr 28, 2010 | Rolex Daytona 116520 Wrist Watch
I recently bought a Kenneth Cole KC 3790 as a gift and I am tying to set the date...the date is presently Saturday 27th February and I am having difficulty getting to the 27th day of February on the...
Pull out crown to the time setting position (second click) and set time to 5.30 pm or am. Push crown back completely. Pull out crown to the date setting position (first click) and set it to 26th, then pull out crown further out to the time setting position (second click) and adjust watch hands forwards until the date changes to 27th. Date is changing at midnight, so, continue to adjust hands forward to the right time. Rate me, plz.
Feb 27, 2010 | Watches
How can i make the date of my tag heuer formula 1 change automaticaly?
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Oct 10, 2009 | Tag Heuer Formula One
How to set date on breitling watches
On most.  Turn the winding screw anti-clockwise until it clicks and pops out slightly. Pull it all the way out or half way out to change the time or date.
Sep 18, 2009 | Breitling A1336313 Bentley Gt Racing Watch
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Bulova 96R000 Watch Logo
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
