Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
My front loader fills with water, pumps and drains fine but the drum never moves or spins . Already cleaned pump, Checked belt and motor, belt is good and motor and drum spin freely.
  • rlivolsi May 21, 2011
    removed back cover, belt and motor look good and all in place. i can spin drum by hand,
    water fills but when it comes time for the the drum to spin nothing happens. If i put the control knob to spin or to drain the pump comes on and pumps the water from the washer but the drum does not spin.
  • 2,510 Answers
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
Posted on May 21, 2011
  • Hans Pearson
    Hans Pearson May 21, 2011
    Try operating the machine while the back is off and see if you can determine why there is no drive to the drum. Look for things like pulley shafts sheared, pulleys not driving their shafts, belts slipping, a clutch that is not driving or even a belt missing/broken. Strictly speaking, you should not be able to move the drum freely, it should drive back to the motor and offer considerable resistance. Remember to maintain a safe distance when the power is on! Come back to me with your findings if you need further advice.
I have a Frigidaire affinity front load washer (fafs4474lwo) it doesn't do the final spin to get the water out of the clothes. I was getting an E52 and E58 codes. I replaced the drive motor and the motor...
Just a thought. If the drum spins when washer is empty that tells me your belt could be shot and just slips when there is a load in it. Check and see if the belt wiggles or appears loose when you squeeze it by hand with the plug pulled of course. If the belt is tight it could be a pulley is spinning on the shaft.
Jul 19, 2017 | Frigidaire Washing Machines
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Water not filling in electrolux front loader, have cleaned out pump and detergent area, require sequence tpo override error
You have checked the pump area,does the pump actually spin when you put control to drain or spin,because if the pump does not function correctly the machine will not bring any more water into the machine.There may still be a problem at the inlet valves etc.
Hope this helps.
Jun 26, 2010 | Washing Machines
Drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
May 03, 2010 | GE WBVH6240F Front Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
241 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
