Question about Maytag Dishwashers
Maytag dishwasher model mdb7100aww, no water input,all else appears ok
  • 2,510 Answers
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working). Please rate this solution.
Posted on May 21, 2011
MDB7100AWW Dishwasher has started making a load noise during operation. Still working for now.
either your main pump is going bad or the drain pump is going bad. it is possible that there is something stuck in the sump causing it to make noise
Oct 24, 2011 | Maytag Dishwasher
Last nigh my Maytag dishwasher model # MDB7100Aww serial # 15666931YM caught fire. Luckily I heard it and was able to put the fire out before my house caught fire. Has there been a recall on this model...
Yes, there was a product recall for your Dishwasher due to fire hazard. Please visit the following pages for further information:
https://repair.maytag.com/repair/dishwasher.jsp?siteCd=MT_EN_US
https://repair.maytag.com/repair/dish_faq.jsp?siteCd=MT_EN_US
The list includes model numbers beginning MDB7 with serial numbers ending in YM, so yours is one of the units affected.
With regard to repair / replacement / compensation, Maytag state the following:
Remedy: Consumers should immediately stop using these dishwashers, disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire. Contact Maytag for either a free in-home repair, or a $75 cash back reimbursement following the purchase of a new Maytag®, Jenn-Air®, Whirlpool® or KitchenAid® dishwasher. Consumers should not return the dishwasher to the retailer where it was purchased, as retailers are not prepared to take units back.
Consumer Contact: For more information, contact Maytag Corporation at (800) 675-0535 anytime, or visit the firm's Web site at www.repair.maytag.com.
Hope this helps - I would advise phoning them on the number above to find out what your exact position is as this recall was issued in 2007. However, there should not be any time limitations on claims and this still appears to be an active recall. They have admitted the dishwashers are dangerous and thereby accepted liability.
Regards,
BElectric
Dec 09, 2010 | Dishwashers
Model MDB7100AWW. Machine washes okay but does not dry dishes. Element tested as okay. No drainage problem. Is there a thermostat that should be replaced?
You have to verify that element is actually receiving voltage at start of dry cycle. Cause will be timer or relay. Be sure to check hi-limit switch and door seal.
Aug 19, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
My dishwasher won't draw in the water. Model MDB7100AWW rgordon@upei.ca
bad water valve. or water supply going to the unit .check them both
Mar 02, 2010 | Dishwashers
Maytag MDB7100AWW Dishwasher how many minimum amps is needed
to find out the amps needed you need to take the wattage that is listed on the information tag on the door of the dishwasher. Take the wattage number and multiply that number by 1000. Take the figure and divide it by the a/c current used to run the dishwasher this total is the minimum amps need for the proper operation of the dishwasher.
Example 35 watts X 1000 = 35000 divided by power supplied say 120 volts 29.1 amps or 30 amps
Hope this helped
Dave
Jan 18, 2010 | Maytag MDB7100AWB Dishwasher
Mdb7100aww maytag, just not draining now. never problems before. water standing in tub and shuts down????? Float appears to be functioning just does not seem to drain, possibly drain motor?
Elimination Of Problems From Most To Least Likely:
1. Connection from discharge hose to drain pipe is blocked/corroded.
a) Loosen the gear clamp (5/16" Nut Driver/Phillips/Standard) holding the discharge hose to the barbed drain fitting.
b) Check that the barbed fitting is not blocked by poking at the opening wth a screwdriver.
c) If the barbed connection is Galvanzied and it has gotten heavily corroded, replacement of that fitting is recommended.
2. Discharge hose is blocked/kinked from dishwasher to drain connection.
a) After 1b), place discharge end of hose into a bucket and run the dishwasher through a cycle.
b) If flow is poor, examine hose for kinking or parts (such as couplings) that may have corroded shut. Removing front panel and using a flashlight will be required for this (1/4" nut driver/phillips) If such corrosion found, 1c).
c) If hose and fittings are ok, there may be an inline filter whose screen is clogged or a filter screen where the dishwasher ties into it's discharge line.
3. Pump has failedinternally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
N.B. May be under warranty - check. May be cheaper just to get another dishwasher at this point, especially if the dishwasher is more than 10 years old.
Aug 08, 2009 | Maytag Dishwashers
Greetings
Everything is fixable, you just need to weigh the cost of repair against a new dishwasher. To help solve your problem, I would need the brand and model number of your dishwasher. Plus, you say it's from the electronics panel? Is this a board in the dishwasher itself or did you mean the electrical panel on the wall?
Feb 22, 2008 | Dishwashers
Dishwashers Logo
123 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
